b16 or b18 into a Sol... need ideas.
Old Mar 6, 2004 | 10:55 AM
jbell's Avatar
Default b16 or b18 into a Sol... need ideas.
******* hell. i lied. im not going h22. its a waste, i dont feel like cutting up my chassis just to get things like shifter cables working.... it seems like too much of a hassle, already ontop of the axles breaking and the low oil pan.
anyway-
i think im gonna go b16 or b18. for $3000... what can i do??
since this is going in either an S or SI del sol, 3000 dollars needs to include- mounts, radiator, vafc, etc. every little part.
im open to alot of ideas... b16/gsr hybrids, high compression, whatever.
TIA.
Old Mar 6, 2004 | 01:45 PM
jbell's Avatar
Default Re: b16 or b18 into a Sol... need ideas. (jbell)
ttt
Old Mar 6, 2004 | 02:03 PM
torr's Avatar
i would go with a b18, becuase of the torue and the option to go with an ls/vtec later.
Old Mar 6, 2004 | 02:13 PM
jbell's Avatar
Default Re: b16 or b18 into a Sol... need ideas. (torr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torr &raquo;</TD></TR><TR><TD CLASS="quote">i would go with a b18, becuase of the torue and the option to go with an ls/vtec later.</TD></TR></TABLE>
good point but isnt the ls slower off the bat?
also, this may seem silly, but do they make a red crinklecoat valvecover for it?
Old Mar 6, 2004 | 02:34 PM
Honsu's Avatar
i would go b18c1, that little bit of extra torque will help you in the long run because the sol is a heavier car than most people think. with a fairly simple turbo setup 300 whp is not that hard to attain. The ls/vtec is nice for the track but is kind of a handful for a daily driver. To me the b18c1 is just the best all around platform you can do almost anything with it, this is why i one in my sol.
what year? and what model s or si? the vtec motors are almost a direct drop in with the si, the s requires more wiring.
Old Mar 6, 2004 | 03:09 PM
jbell's Avatar
Default Re: b16 or b18 into a Sol... need ideas. (Honsu)
im planning on picking up an SI.. which will have all the vtec and whatnot..
so you guys reccomend a b18c1 (ls) and then either swap on a vtec head or a turbo kit down the road?
sounds good to me.
only thing.. do they make a red valve cover for the ls?
Old Mar 6, 2004 | 03:47 PM
Kendall's Avatar
Alright first, the B18C1 is a GSR engine, not an LS engine. Second, you can get red valve covers for the LS engine off of ebay, but they say DOHC VTEC and would thus make you a ricer.
Now to the discussion at hand. For cheap speed, I'd get an LS motor (B18B1) and a turbo. For an all motor setup, I'd start with the B18C1 and go from there.
But if I were doing this, I'd just get a Del Sol VTEC which already has a B16 in it, and then go LS/VTEC.
Old Mar 6, 2004 | 04:59 PM
jbell's Avatar
Default Re: (Grizzly Adams)
i dont think i could pull off a ls turbo for my budget.
i think i could barely pull off a ls vtec for my budget.
i dont want to swap in a ls and call it a day though... i rather swap in a b16 and have the vtec.
Old Mar 6, 2004 | 07:12 PM
jbell's Avatar
Default Re: (jbell)
bump.
Old Mar 6, 2004 | 07:22 PM
Kendall's Avatar
For $3000 you can get an LS and be well on your way to a turbo setup. If you aren't willing to do this, then I think your best bet would be a second gen B16A.
Old Mar 6, 2004 | 07:24 PM
jbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grizzly Adams &raquo;</TD></TR><TR><TD CLASS="quote">For $3000 you can get an LS and be well on your way to a turbo setup. If you aren't willing to do this, then I think your best bet would be a second gen B16A.</TD></TR></TABLE>
any reccomended supporting mods for the b16?
Old Mar 6, 2004 | 07:26 PM
Kendall's Avatar
While doing the swap, I'd go ahead and put in a good header and intake. Personally I'd put in some CTR cams and run the DIY ITB setup. It all comes down to what goals you have.
Old Mar 6, 2004 | 07:36 PM
jbell's Avatar
diy itb???
its gonna be a daily driver... i like... or better yet... i love the idea of itb, but can i use a filter on each one? or what?
Modified by jbell at 4:49 AM 3/7/2004
Old Mar 6, 2004 | 08:50 PM
quik sol's Avatar
skip the vafc...its a waste of time...
Old Mar 6, 2004 | 10:18 PM
jbell's Avatar
Default Re: (quik sol)
why do you say that?
Old Mar 6, 2004 | 11:12 PM
jbell's Avatar
Default Re: (jbell)
hrm. im thinking-
b16, adjustable cam gears, performance cams, good header, and itb's
can you guys reccomend some good "bang for the buck" parts- as in cheap gears, cams and itb's that are inexpensive, but offer good performance. i know there is a middle range that isn't too expensive, and aren't pieces of crap.
as for the itb's... can i put filters on each of the pipes? i love the idea of having them on a daily driver... but dont want to risk sucking up... everything.
Old Mar 7, 2004 | 09:24 AM
dfoxengr's Avatar
Default Re: (jbell)
dont jumpon the bandwagon ITB boat with that low comp. untuned low budget motor.
Old Mar 7, 2004 | 09:31 AM
jbell's Avatar
Default Re: (hybridvteceg)
what is considered low compression?
oh, it will be tuned.
Old Mar 7, 2004 | 11:03 AM
jbell's Avatar
Default Re: (jbell)
ttt
tpep13
27
Aug 29, 2007 10:08 PM
95dsol
May 7, 2007 01:53 PM
Itzmy91Teg
66
Nov 30, 2006 02:50 AM
Fiero
Oct 9, 2006 08:48 PM
b16vtecsol
11
Nov 9, 2003 04:10 PM
