differance between LSD trans and non LSD
i was just wondering how you can tell between a transmission with LSD or without buy just looking into the axles holes? because i have a h22 from japan and i just wanted to know if it was a LSD or not. thanx
most have lsd stamped on the trans casing. if not jut pull the axles, if you can see through it no lsd. if you can't see through it, lsd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">get the tranny code, like M2B4.. or just look through the differential, straight through is LSD</TD></TR></TABLE>
Straight through = LSD
Metal pin across = non-LSD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgiajdm »</TD></TR><TR><TD CLASS="quote">most have lsd stamped on the trans casing. if not jut pull the axles, if you can see through it no lsd. if you can't see through it, lsd.</TD></TR></TABLE>
Don't think you need to pull the axles.. If the tranny is installed then just spin the wheels in the air, if both wheels..
spin in the same direction = LSD
opposite directions = NO LSD
