HELP FAST! civic e-brake cable problem on rear disk conversion
hey guys i just did my integra brake swap and put SS brake lines on all four corners, my problem is the e-brake cable, i just cut the old cable off so i could put the integra trailing arms on.
the cable look like they run under the exhaust and an exhaust shield.
Do i need to drop my exhaust to remove them?
Any one got pics and/or a step by step to help finish this real quick.
Cliff notes: i need a step by step on how to unhook and remove old civic e-brake cables and install new ones.
No you just need to remove teh exhaust shield to get at the cable, and the replace it with the integra cable the same way as you took the old one off.
AIM me @ l1smarrow if you get stuck.
If you take out the center console there two blots that for the bracket that holds the e-brakes on the inside of the car. On the underside there are three blots on both sides. Two at the back of the gas tank that hold the cables and one on the trailing arm. I believe there all 12mm, and Like greebler said you only have to take out the heat shield to get the e-brake cables out.
JDM_EK_JOE
Jul 25, 2006 10:39 AM
FernEF
Feb 13, 2006 07:42 PM
Tomek
Jan 8, 2004 11:56 PM
