how do you make a kill switch??
Try searching HT or try searching Google.com.
For this to be effective you need a few (the more the merrier) and put them where you think they are hidden.
Good Luck
Good Luck
unfortunetly people who like to steal cars can also read this forum and thus try not to discuss where you put your switches, how you wired it et cetera
http://www.courtlukens.com/cutoff_switch.htm
Thats for a 92-95 That should give you everything you need. I made one and it works great
Its pretty straight forward but if you need help just PM me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 »</TD></TR><TR><TD CLASS="quote">the 12v from your ecu </TD></TR></TABLE>
Why don't more people disable the ECU? Seems like it would be pretty easy to jump 12v to the pump. Wouldn't it be harder to override an ECU kill?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B and B »</TD></TR><TR><TD CLASS="quote">Why don't more people disable the ECU? Seems like it would be pretty easy to jump 12v to the pump. Wouldn't it be harder to override an ECU kill?</TD></TR></TABLE>
Or..... just take the ECU, seems logical to me.
lots and lots of ways.....
i dont have any kill switches , but i would do an ignition kill under the hood....not in the cab.... spice a switch and solder it in , in the ignition wire to the starter.....
also if you are really paranoid, you can do a fuel cut off switch too
just make sure you solder your connections, id hate to hack up a perfect harness
i just take my whole ecu with me whenever im parked somewhere i dont know
stinkypinky1011
21
Nov 11, 2013 11:18 PM
