Jimfab Traction Bars = Noisy??
I just installed my jimfab traction bars a couple days ago, and noticed that they make a popping sound under braking (and also sometimes when hitting a dip in the road while turning).
Has anyone experienced this? Before when I had 0 preload, it was making more noise, but it was more like "clanging", but now i can make a consistant "pop" noise under braking. I can do it consistantly too.
Thanks
Thanks
UPDATE** If anybody else has this problem
It was a loose heim joint on the passenger side control arm. The rod end was not fully tightened and when I was braking, it was being pushed to the side and hit the metal bracket.
I tightened it up GOOD, put three turns of preload, lubed up the rod ends with some lithium grease and they don't make a sound now.
For the JIMFAB traction bar!
