Engine Swap
Hey guys, I was wondering if anyone knew if I did a swap with a H22A in my 94 Accord EX, would I need to replace my header, exhust, Cold Air Intake or Rims because of the engine swap? I am thinking about doing that and don't want to have to replace anything.
you will have to replace the header because the bolt pattern on the heads arent the same...u can make the exhaust work...other than that u are fine should be no problems.
a stock exhaust manifold comes with the h22 when u buy it most of the time, part of the stock intake comes with it and you could go cheap and stick a filter on the end of the black tube, buy an intake, or connect the tube to your stock airbox. rims dont matter
u wont have to change the axles (FF cars dont have driveshafts) unless ur running serious power......and u can get beefier axles and keep the same hubs (4 lug)
Hatchdude
Apr 19, 2004 06:59 PM
