WTB - Ground Control Upper Mount "top hats"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egMee »</TD></TR><TR><TD CLASS="quote">good luck gettin them. took me 2 months to order mines. its worth it though</TD></TR></TABLE>
How so? what do these do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xpsonic »</TD></TR><TR><TD CLASS="quote">ya just call them, i got all four in like 2 weeks cause the gunmetal ones were still in the shop, but i got them in all four corners.
hey im about to install mine but i dont know what i should do about the bump stops which ones did you use cause i had them come with the ground control top hats, and on my rear shocks only not on the fronts. do you have to shorten them? if so how much? and the ground control bumpstops are smaller then the ones that came on my shocks. and even then they only came on the rear shocks. im confused with all this....
</TD></TR></TABLE>hey im about to install mine but i dont know what i should do about the bump stops which ones did you use cause i had them come with the ground control top hats, and on my rear shocks only not on the fronts. do you have to shorten them? if so how much? and the ground control bumpstops are smaller then the ones that came on my shocks. and even then they only came on the rear shocks. im confused with all this....
there's a user on here that makes custom top hats for most hondas for a lot cheaper than the GC one's. here is his thread.
https://honda-tech.com/zerothread?id=848887
hasback*
Jul 20, 2007 05:32 PM
and even with all the new stuff they added
