what do you think my output should be?
I'm rebuilding my 96' gsr b18c with JE 9:1 pistons 20mm over, eagle rods, block guard and all the other necessary stuff required to rebuild the bottom ie: oil and water pump etc...and then I'm slapping an fmax turbo kit on. What do you think the max amount of boost I can run safely? And what do you think my whp will be? This is before proper tuning, hondata etc. Just right after everything is pieced together.
most likely pretty crappy, maybe very low 200's at 7 psi. Personally i would recommend another kit, but its up to you. I feel that there are better kits available. With hondata and other tuning essentials i could easily see you making over 300whp on an fmax kit, but it will require more fuel (injectors, pump, fpr) and tuning.
1badITR
Jul 19, 2002 09:42 AM
