91 civic w/ b16 turbo having o2 sensor problems CEL
Old Mar 5, 2004 | 05:58 PM
EVOCELICA's Avatar
New User
Default 91 civic w/ b16 turbo having o2 sensor problems CEL
I got a code one showing on my pr3 ecu I replaced both o2 sensors cleared the ECU and started the car up and still have a CEL of one. No idea what's going on can anyone let me know what this could be. I just start the car not drive it should I have to drive it and get the temp up and hope the CEL goes away, or does the CEL clear after the ECU is reset.
Old Mar 5, 2004 | 08:20 PM
EVOCELICA's Avatar
New User
Default Re: 91 civic w/ b16 turbo having o2 sensor problems CEL (EVOCELICA)
anyone any help
Old Mar 6, 2004 | 08:04 AM
EVOCELICA's Avatar
New User
any help
Old Mar 6, 2004 | 11:12 AM
EVOCELICA's Avatar
New User
no one knows
Old Mar 6, 2004 | 03:51 PM
EVOCELICA's Avatar
New User
this is a messege board right
Old Mar 7, 2004 | 08:39 AM
EVOCELICA's Avatar
New User
bump
Old Mar 7, 2004 | 11:40 PM
EVOCELICA's Avatar
New User
bump again
Old Mar 8, 2004 | 05:06 AM
virginia_dude's Avatar
the Pr3 expects one sensor to read Cylinders 1+4 and the other 2+3, how did you manage to do this AND put a turbo on it?
Old Mar 8, 2004 | 07:41 AM
EVOCELICA's Avatar
New User
Default Re: 91 civic w/ b16 turbo having o2 sensor problems CEL (virginia_dude)
the guy who built ny down pipe put 2 bungs in right before the cat on the down pipe, it worked fine for a year with out a problem.
Old Mar 8, 2004 | 07:46 AM
yes but the PR3 or PW0 controls pairs of cylinfers if the O2 sensor sees other than the 2 it controls it will not get mixtures right. and 2 O2 sensors on a common downpipe will not let it control right. Unless its chipped for one O2 sensor then it runs like crap or you do ODB1 converion and it uses one O2 sensor the way it should. Something to keep in mind, I doubt a ODB0 ecu is going to be the best for you for this reason.
But I bet one of the two is having a problem THat is why you have a CEL, check continuity of wiring. Or one is bad.
Old Mar 8, 2004 | 04:00 PM
EVOCELICA's Avatar
New User
so you think it could just be a bad wire
Old Mar 9, 2004 | 07:10 AM
EVOCELICA's Avatar
New User
thanks for all the help everyone still have no idea what's wrong
Old Mar 9, 2004 | 07:12 AM
the ECU is not seeing anything from one of the two O2 sensors, bad wire or bad O2 sensor.
sampson100
Dec 10, 2010 08:12 AM
project91crxsi
41
Oct 30, 2009 04:56 PM
gsrvtechatch93
Mar 29, 2004 08:48 PM
b16wannaride
Sep 16, 2002 12:02 PM
comptechgsr2000
Apr 25, 2002 09:26 PM
