SRR LCA install pics---On my 00 EM1
Well I got around to installing my Srr LCA's on my 00 civic si. The install was simple. I was using air-tools and it only took me about 30 minutes to do. It took longer to take off the wheels and set the jack-stands than the actual LCA swap.I didn't run into any problems other than one of the LCA falling on my damn head...oooochhhhh I took a-lot of pics enjoy!!
(BEFORE)
(orginal arm)
(after)
(BEFORE)
(orginal arm)
(after)
$185 shipped from andy at perpetualconcepts.
If I have some time I will do a how to. As far as camber adjustment no.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">This would be much nicer if you made it a how to.</TD></TR></TABLE>]
lol, you need a how to on installing lcas? There are 3 bolts. Take them out, pull out old lca, put in new lca, reinstall bolts. In this case, he had to undo his tie bar, and then reattatch it.
You are lucky... it took me forever because of the MN winters. Everything was rusted to ****, 2 of the bolts snapped off even using air tools. Good times
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diearzte2 »</TD></TR><TR><TD CLASS="quote">]
lol, you need a how to on installing lcas? </TD></TR></TABLE>
No, I don't need a how-to. But others may and this is off topic if it has nothing technical as in a install. Appearance and Cosmetic are for "Look at my Car" posts.
Make it tech or post it somewhere else.
jack car up
support properly
take rear wheels off
impact 3 14 mm bolts off....
impact 12 mm swaybar bolt
drop old LCA out
replace with new one....
repeat in reverse order....
done
15 minutes tops....like he said longer to take wheels off and to jack it up!
jack car up
support properly
drop old LCA out
done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_Siii »</TD></TR><TR><TD CLASS="quote">Nice, didn't know they made them in blue</TD></TR></TABLE>
I think they're purple, they just look lighter in the picture.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Airbag Club »</TD></TR><TR><TD CLASS="quote">looks like the same color combo i had going, before i painted my LCA's....</TD></TR></TABLE>
I've got that goin on too. Purple Control Arms, Green Shocks, and Red upper a arms in the front
