Got rid of speed bleeders; bleeding with the stock bleed screws
Old Mar 5, 2004 | 04:44 PM
onyx00's Avatar
Default Got rid of speed bleeders; bleeding with the stock bleed screws
Just wanted to make sure I was doing this right:
1.) Friends pumps pedal several times (5-10).
2.) I open the bleed screw and friend pushes pedal down (making sure not to touch the floor).
3.) Friend holds pedal
4.) I close bleed screw
5.) Friends lets go of pedal
6.) Repeat for each caliper (starting from drivers side front, then to passengerside front, then to passenger side rear, then to drivers side rear).
Is this correct? Thanks! :-)
Old Mar 5, 2004 | 04:49 PM
Rob :190:'s Avatar
Default Re: Got rid of speed bleeders; bleeding with the stock bleed screws (onyx00)
I always thought you did the Pass. Rear, Drivers rear, pass. front, drivers front
Old Mar 5, 2004 | 05:31 PM
CPR's Avatar
CPR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onyx00 &raquo;</TD></TR><TR><TD CLASS="quote">Just wanted to make sure I was doing this right:
Is this correct? Thanks! :-)</TD></TR></TABLE>
Yes, this series of steps is correct.
1GreyTeg's Avatar
Default Re: Got rid of speed bleeders; bleeding with the stock bleed screws (CPR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CPR &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, this series of steps is correct.</TD></TR></TABLE>
ditto.
Old Mar 5, 2004 | 05:35 PM
onyx00's Avatar
Default Re: Got rid of speed bleeders; bleeding with the stock bleed screws (1GreyTeg)
Awesome, thanks for the help guys, much appreciated!
Old Mar 5, 2004 | 06:30 PM
Chris N's Avatar
Default Re: Got rid of speed bleeders; bleeding with the stock bleed screws (Rob :190:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob :190: &raquo;</TD></TR><TR><TD CLASS="quote">I always thought you did the Pass. Rear, Drivers rear, pass. front, drivers front</TD></TR></TABLE>
The 94-97 integra manual says that. I believe the cibac manuals are like that too.
The 98-01 integra manual says DF, PF, PR, DR or FL, FR, RR, RL.
Old Mar 5, 2004 | 06:38 PM
1GreyTeg's Avatar
Default Re: Got rid of speed bleeders; bleeding with the stock bleed screws (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">
The 98-01 integra manual says DF, PF, PR, DR or FL, FR, RR, RL.</TD></TR></TABLE>
dmnoppqr,, ok, whatever.
Old Mar 5, 2004 | 07:28 PM
thk's Avatar
thk
Members Only
Yeah. rodney almost kicked my butt when I said I bled the rears first. I started doing the FL, FR, RR and RL method after I put on my new calipers.
Old Mar 5, 2004 | 07:35 PM
hpfsi's Avatar
Default Re: Got rid of speed bleeders; bleeding with the stock bleed screws (thk)
Don't you just want to work from longest to shortest in terms of line length to the caliper?
Old Mar 5, 2004 | 07:37 PM
1GreyTeg's Avatar
Default Re: Got rid of speed bleeders; bleeding with the stock bleed screws (hpfsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hpfsi &raquo;</TD></TR><TR><TD CLASS="quote">Don't you just want to work from longest to shortest in terms of line length to the caliper?</TD></TR></TABLE>
The lines cross with the ABS in the R/Teg whatever.
We follow what the Helm's dictates.
Call me a Helm's slave, I could give a hoot, as long as my car stops when I need it to.
thk's Avatar
thk
Members Only
You mean master cylinder, right?
And I thought so too but if rodney says otherwise and the Helms confirms it, I'm going to do it the "right way".
Old Mar 5, 2004 | 07:41 PM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk &raquo;</TD></TR><TR><TD CLASS="quote">
And I thought so too but if rodney says otherwise and the Helms confirms it, I'm going to do it the "right way".</TD></TR></TABLE>
Rodney, Rodney, Rodney.
Marsha, Marsha, Marsha.
Any coincidence is purely coincidental.
Old Mar 5, 2004 | 07:48 PM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">dmnoppqr,, ok, whatever.</TD></TR></TABLE>
LOL.
Listen to me, bitches!
Old Mar 5, 2004 | 11:43 PM
goern-R's Avatar
Why not to the floor? I've always done it that way.
Old Mar 5, 2004 | 11:48 PM
B2FiNiTY's Avatar
Default Re: Got rid of speed bleeders; bleeding with the stock bleed screws (goern-R)
It is bad for the MC.
Old Mar 6, 2004 | 05:23 AM
Cosworth's Avatar
[QUOTE=onyx00]
QUOTE]
Get a 2x4 wood block and place it under the brake pedal. Then, you never have to worry about the pedal going down to the floor.
Old Mar 6, 2004 | 06:49 AM
davidnyc's Avatar
Default Re: Got rid of speed bleeders; bleeding with the stock bleed screws (Cosworth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cosworth &raquo;</TD></TR><TR><TD CLASS="quote">
Get a 2x4 wood block and place it under the brake pedal. Then, you never have to worry about the pedal going down to the floor. </TD></TR></TABLE>
Aaahhhh!! good idea ! Sometimes the most simple solutions are the best.
Old Mar 6, 2004 | 08:16 AM
goern-R's Avatar
Default Re: Got rid of speed bleeders; bleeding with the stock bleed screws (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">It is bad for the MC. </TD></TR></TABLE>
Hmm.. Good to know. Thanks. I'll do the wood trick from now on.
I just hope I haven't f'd up my MC yet.
BTW, Chris- Where've you been? You still in town? I haven't seen you at an event in ages.
Old Mar 6, 2004 | 12:07 PM
onyx00's Avatar
Yup still in town. Been busy, graduating and moving up to Peoria to work for Honeywell. Thi8nk I got a bad master cylinder, but oh well.
You still going to track events? When is the next one you will be at? Toss me a PM man!
Old Mar 6, 2004 | 04:16 PM
Cosworth's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onyx00 &raquo;</TD></TR><TR><TD CLASS="quote"> Thi8nk I got a bad master cylinder, but oh well.</TD></TR></TABLE>
That sux. Bad MC sucks big donkey nuts. Change it out fast... you don't want it to go out on you on a hot summer day. It's not fun trying to stop the car w/ emergency/parking brakes. Ask me how I know.
Old Mar 7, 2004 | 09:27 AM
onyx00's Avatar
Yeah, well I want to make sure first so I am letting the cr go for a week or so first. I barely drive it as is.
Old Mar 7, 2004 | 11:44 AM
Dr Pooface's Avatar
1. Put tube connected to bleed screw in a pop bottle with some brake fluid in the bottom, so the end of the tube is covered in fluid.
2. open screw and pump pedal to hearts content.
3. close screw.
courtney42
10
Dec 28, 2008 03:52 PM
aut0tek
May 1, 2007 09:26 PM
NitrousB.I.G.
Jan 22, 2006 10:37 PM
tegrunner
Jan 22, 2004 02:23 PM
Mr. Choi
Feb 24, 2003 03:18 PM
