1989 Legend code 4
ok so my buds 1989 Legend with a 2.7L V-6 is throwing a
code 4 (crank position sensor)
what are possible causes of this and some possible solutions for this
Thanks H-T OWNES
Thanks H-T OWNES
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 »</TD></TR><TR><TD CLASS="quote">(crank position sensor)
Is that in the distributor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 »</TD></TR><TR><TD CLASS="quote">are you foreal?</TD></TR></TABLE>
Most older Honda 4 cylinder engines have the crank position sensor in the distributor. I'm not sure about the older v6s.I was just trying to help, you don't have to be a dick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 »</TD></TR><TR><TD CLASS="quote">oh sry i did not know it was in the dizzy
I don't know if it"s in the dist. or not, I was asking. If it is I would suggest Looking in the distributor cap for brown dust. Otherwise check the wiring and connectors, and the resistance of the sensor itself.
On that year V-6 the Crank Angle position sensor could also be i the front bank cam area, just under the timing belt cover, but its easier to check the resistance on the plug do determine if its bad or not, unless of course its in the dist.
Good Luck
Good Luck
Hmm, not sure where this is located though I probably should. I'm only familiar with the more common problems involving the Legend.
If no luck, you might want to check out acura-legend.com and their forums for help.
JaHnAbOi
Mar 1, 2005 02:44 PM
