How much time to R+R an intake to block gasket on 89 LXi?
Old Mar 5, 2004 | 02:37 PM
POS's Avatar
POS
Default How much time to R+R an intake to block gasket on 89 LXi?
I think I may have found the reason for my 2000 rpm idle at startup and generally high/loping idle. Sprayed some carb cleaner around the intake and sure enough, the intake gasket is leaking.
How long should this take? It looks pretty straightforward, disconnect fuel rail, vacuum lines and any other fittings, drain coolant, unbolt intake. Is that it? I'm away at school and am wondering if I can do this in my driveway.
Thanks.
Old Mar 5, 2004 | 02:48 PM
InjectedPerformance's Avatar
We sell parts.
Default Re: How much time to R+R an intake to block gasket on 89 LXi? (POS)
Sure can. Good luck.
We sell parts.
Default Re: How much time to R+R an intake to block gasket on 89 LXi? (primo8998)
Could take a couple of hours.
Old Mar 6, 2004 | 02:10 PM
BigLoadChoakHard's Avatar
intake manifold is bolted to the block its bolted to the cylinder head
Old Mar 6, 2004 | 05:06 PM
POS's Avatar
POS
Default Re: How much time to R+R an intake to block gasket on 89 LXi? (BigLoadChoakHard)
Yeah, i realized that after i posted. Amazing what a few beers will do. Thanks, I'll give this a shot, maybe it will help my **** poor gas mileage.
turbocivic1984
Jun 25, 2008 03:48 PM
ericstambaugh07
Mar 13, 2007 05:10 PM
koa
Jan 4, 2007 10:58 AM
SimplyTron
Jan 26, 2006 08:19 PM
Br1anPham
Jan 26, 2004 07:24 AM
