Transmission Fluid
Old Mar 5, 2004 | 02:29 PM
Vtec92Civic's Avatar
Default Transmission Fluid
Today I am dropping my y8 motor in, but I am un-sure about what to use as far as transmission fluid . . . . anyone have any good advice or anything that could help me in deciding what to get?
I would like to finish the install today and fire the car up, so hope to get some responces soon
Thanks
Old Mar 5, 2004 | 02:37 PM
2lua's Avatar
Default Re: Transmission Fluid (Vtec92Civic)
what year and how many miles? if a lot then i would get the gm synchro mesh with friction modifier.
Old Mar 5, 2004 | 02:45 PM
dantastic's Avatar
honda mtf works well for me. i've also used regular 10w30 too. works good
Old Mar 5, 2004 | 02:47 PM
upsidedowncake's Avatar
you r supposed to use 10-30 they make a lttle tube with an attachment for it with a little pump for the top of oil quarts.
Old Mar 5, 2004 | 02:49 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Transmission Fluid (upsidedowncake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by upsidedowncake &raquo;</TD></TR><TR><TD CLASS="quote">you r supposed to use 10-30 they make a lttle tube with an attachment for it with a little pump for the top of oil quarts. </TD></TR></TABLE>
actually you are supposed to use HG MTF. but 10w30 will work in a pinch. takes about 2.5-2.8 quarts. i always fill from the speed sensor, overfill with three then pop out the fill plug and let the excess run out.
Old Mar 5, 2004 | 02:55 PM
a friend of mine also adds like a 1/4 quart of lucas stabilzer. he likes to run it didnt smoke a tranny yet. just remember the word "YET"
Old Mar 6, 2004 | 08:43 PM
Default Re: Transmission Fluid (boostedcivicsir)
thanks guys . . . I think i'm gona run 10w 30 just for now then switch it up
What's the deal with filling it from the speed sensor? I only heard rumors, but how is this done?
Old Mar 6, 2004 | 09:08 PM
Frozen E's Avatar
H-T White Ops
Well, you're probably done with it by now, but if you're going to drain it again look into getting some GM synchro mesh fluid. Worked wonders for my Lude.
honda-guy72
32
Sep 21, 2008 09:54 PM
innes887
22
Apr 14, 2007 05:00 PM
B-CRX
Nov 16, 2006 01:44 PM
Pr0jektLude
Sep 2, 2004 05:39 AM
teg-ga
Jul 20, 2004 02:48 PM
