-is it ok to mix leaded race fuel (114) with 91 oct?
Old Mar 5, 2004 | 02:05 PM
marieT1GRL's Avatar
Default -is it ok to mix leaded race fuel (114) with 91 oct?
searched, but nothing found i have a built 85mm LS-V with wiesco 12.5:1 pistons, just wondering what would the octane be, and if its possible to mix.. im going to the dyno in a couple of days, dont wanna ruin the motor on 91
-marie
Old Mar 5, 2004 | 04:58 PM
Kendall's Avatar
Unless you're running an engine that was built to run leaded fuel (for instance, old V8's) then I would stay away from it. Try finding some C16, or perhaps a toluene mixture.
Old Mar 5, 2004 | 06:27 PM
scrambledeg's Avatar
Default Re: -is it ok to mix leaded race fuel (114) with 91 oct? (ThatOneGirl)
Theres nothing wrong with using leaded fuel or a mix of both, just as long as you do not have a catalytic converter on. Supposedly it will ruin the cat by clogging it I guess thats why odler v-8s used leaded fuel due the lack of emmision equipment on them. Also the lead in the fuel I was told that it helped out in the combustion chamber cause it has some lubrication properties. And I have personally run 116 octane leaded and 92 at the track and streets with no problems at all. Hope this helps.
Old Mar 5, 2004 | 06:29 PM
func-tion's Avatar
Default Re: -is it ok to mix leaded race fuel (scrambledeg)
yep leaded fuel wil ruin your cat and sensors. Anoter option would be to find a local staion that has a 100 octane pump.
Old Mar 5, 2004 | 07:13 PM
marieT1GRL's Avatar
Default Re: -is it ok to mix leaded race fuel (func-tion)
thanks for all your help...
-marie
Old Mar 6, 2004 | 05:22 AM
CRneXt's Avatar
Actually the clogging of the cat is only a side problem.
The reason the older V-8 engines ran leaded fuel was because they hadn't at that time learned of hardnend valve seats. The primary concern was that the valves would sink in thier seats due to higher operation temp, thus also speeding wear.
A research and study was done by Chevron, and they concluded that unleaded gas will work fine in classic automobiles, as they are not subjected to the use and driving of days gone.
Some further information can be found by clicking here:
http://www.chevron.com/prodser...shtml
I know that this isn't an answer to the original question, but I saw a slight misinfo, and wanted to correct the situation.
Thanks,
Scott
Modified by CRneXt at 8:39 AM 3/6/2004
2fast4urass
Acura TSX
13
Dec 19, 2011 05:34 AM
sc4dr
Jan 16, 2011 02:30 PM
Dave_Dc2
Nov 19, 2008 04:14 PM
ToryluvshisDA
May 6, 2008 04:46 PM
