b16 swap with iac probs
Old Mar 5, 2004 | 01:58 PM
civic ex si's Avatar
Default b16 swap with iac probs
d16y8 swapped to b16a2 and now my idle jerks at 15ish and after 15 there is no even idle its either faster or slower. did engine code..... iac valve anybody have any ideas other then buyin new?
Old Mar 5, 2004 | 02:02 PM
Spade's Avatar
Default Re: b16 swap with iac probs (civic ex si)
Take it off and hose the little bastard with a can of carb cleaner.
Old Mar 5, 2004 | 02:09 PM
Cvic90's Avatar
Which ecu are you running. I did an ls swap in a 96 and had to move the iac wire in the factory harness using an obd1 ecu and jumper.
Old Mar 6, 2004 | 08:59 AM
Default Re: b16 swap with iac probs (Cvic90)
at first i had a p2p ex ecu cause i was lookin for a ecu then a p72 now im with obd1 p30skunk2 chipped
Old Mar 6, 2004 | 09:01 AM
did same jerk with all ecu's
boostgoblin
Engine Management and Tuning
Dec 27, 2017 07:51 PM
bb4socal
Southern California
Aug 15, 2011 10:09 PM
JDM VIC
Mar 4, 2006 02:25 PM
ev0luti0n
Sep 27, 2005 07:42 AM
spatula
Jul 19, 2005 01:25 PM
