Prelude Bore Q?
i belive stock honda head gaskets are all 1mm larger than the stock bore. so ours stock is an 87mmbore and the head gaske is a 88mm,
similarly in my project for the f22 vtec i am using a f23 head gasket, the f23 has a 86mm bore , so it is a 87m head gasket, it matches up exactly to the prelude bore when put on the block.
just like anthony said you should be fine with stock,
1badITR
Jan 22, 2003 09:38 PM
