Question: ITR axles... other model that fits?
Ok, I need new axles for my ITR because I busted the CV joints, So I went to Autozone to get new ones but they dont carry new axles for the ITR, So my question is will GSR axles work on my ITR or maybe Del Sol Vtec Axles?
thanks guys...
thanks guys...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jascon »</TD></TR><TR><TD CLASS="quote">i remember hearing that CRV axles work.. and that theyre pretty strong.. can anyone confirm?</TD></TR></TABLE>
thats what I heard too , anyone?
i recommend you order from raxles. their axles are only $120/each and are made with brand new cv joints and boots and are packed with amsoil synthetic grease. i can't see ever buying remanufactured autozone stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by visi0n »</TD></TR><TR><TD CLASS="quote">hehe what fits on the JDM itr 5 lug?</TD></TR></TABLE>
if you have the 36mm diameter nut on the outer spline
then you need to get jdm axles
the only other axles that i know you can use are the GSR axles, being that they have the ABS ring if you have ABS on your Type R. The Si, LS...do NOT have the ABS ring, I am not sure about the CRV axles either, But from what i know, ALL USDM B series axles are the same fitment, just the only thing that differs them is the ABS Ring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">if you have the 36mm diameter nut on the outer spline
then you need to get jdm axles</TD></TR></TABLE>
nah i have 36mm spline from 98 jdm itr 5lug and you have use 97+ prelude axles as well, they are the same as JDM itr axles. actually a bit beefier
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-PIMP »</TD></TR><TR><TD CLASS="quote">'94-'01 Integra VTEC
'94-'97 del Sol DOHC VTEC
'99-'00 SI
All of the above axles will work on your car, for sure.
He's right i just went through this ordeal not a week ago
'99-'00 SI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R 98-870 »</TD></TR><TR><TD CLASS="quote">so im guessing JDM would axles fit usdm R's? if so the prelude 97 + Fit The usdm Type R too?</TD></TR></TABLE>
no
the usdm hubs are a little different
than the jdm ones
no
than the jdm ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon »</TD></TR><TR><TD CLASS="quote">
nah i have 36mm spline from 98 jdm itr 5lug and you have use 97+ prelude axles as well, they are the same as JDM itr axles. actually a bit beefier</TD></TR></TABLE>
didn't realize you could use those, good ****
handa
Jun 14, 2005 09:00 PM
