92-93 lude si motor crank question
Old Mar 5, 2004 | 04:59 AM
scratchy's Avatar
Default 92-93 lude si motor crank question
need to know if the h-23 has a steel crank need to know please help found a motor that has spun a rod bearing and need to know if i can turn it if so i can rebuild that motor
Old Mar 5, 2004 | 05:21 AM
scratchy's Avatar
Default Re: 92-93 lude si motor crank question (scratchy)
bump need to know please help don't have much time to decide
Old Mar 5, 2004 | 09:36 AM
SKDRCR's Avatar
if you spun a rod bearing and not a main bearing,
you should be able to use your original crank.
Old Mar 15, 2004 | 11:35 AM
93H22ACX's Avatar
Default Re: 92-93 lude si motor crank question (SKDRCR)
what happens if you spun your main bearings?
Old Mar 15, 2004 | 11:55 AM
AndyD's Avatar
Default Re: 92-93 lude si motor crank question (95PRELUDEVTEC206)
Spinning main bearings is caused by lack of oil which leads to the crank area touching the main bearing. When they touch, it torques the bearing. To what degree depends on how little oil there was and how fast the crank was spinning.
When a main bearing spins, it also cuts into the jounal where it sits. Depending on how much metal is sheered away, a machine shop might be able to bore out all the main journals if you supply them with oversized bearings.
Now the crank is a different story. You can turn the crank, but you can't take off too much. Remember, it all has the fit back together and remain in spec.
Also, you can spin one bearing and not the others.
Bottomline; It all despends on how severely the crank torqued the main bearing.
Old Mar 15, 2004 | 04:10 PM
jdmlude_dude's Avatar
Default Re: 92-93 lude si motor crank question (AndyD)
If you spun a bearing, i would recommend just buying a new crank. Having it turned will more than likely cause the bearing sizes to be out of spec. I have one for sale.
Old Mar 15, 2004 | 04:44 PM
93H22ACX's Avatar
Default Re: 92-93 lude si motor crank question (jdmlude_dude)
how much for your 2.3 SI crank?
and do you still have the block?
Old Mar 15, 2004 | 06:31 PM
Qfactor's Avatar
just get an accord 90-97 crank same $hit, you will pay more due to the name that it came off a Prelude.
Old Mar 15, 2004 | 07:28 PM
AndyD's Avatar
Default Re: 92-93 lude si motor crank question (Qfactor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qfactor &raquo;</TD></TR><TR><TD CLASS="quote">just get an accord 90-97 crank same $hit, you will pay more due to the name that it came off a Prelude.</TD></TR></TABLE>
agree
Old Mar 15, 2004 | 08:05 PM
I wouldnt get an accord crank. People think that all honda parts are the same. If so they would all make the same power. Never shorthand yourself when it comes to buying parts...and never use accord parts on a prelude. Prelude parts are make for preludes, accords for accords. I will make you a good deal on the crank..make and offer and we will talk. I can get you pics this weekend. It has roughly 130,000 miles on it. It is out of a 92 si. The block has already been sold. However i know where one is that i can hook you up with for cheap if you are interested. I will have to talk to my friend bout that one.
Old Mar 15, 2004 | 08:32 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude_dude &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt get an accord crank. People think that all honda parts are the same. If so they would all make the same power. Never shorthand yourself when it comes to buying parts...and never use accord parts on a prelude. Prelude parts are make for preludes, accords for accords. I will make you a good deal on the crank..make and offer and we will talk. I can get you pics this weekend. It has roughly 130,000 miles on it. It is out of a 92 si. The block has already been sold. However i know where one is that i can hook you up with for cheap if you are interested. I will have to talk to my friend bout that one.</TD></TR></TABLE>
When a car company uses the EXACT same parts between other motors, it doesn't matter which one you use; they aren't different just b/c one's in a Prelude and one's in an Accord; Honda made them the exact same to cut costs.
I would actually bet that an Accord crank would be better since they were bought as economy cars, while Preludes have a greater tendency to be dogged on.
Old Mar 15, 2004 | 09:30 PM
Qfactor's Avatar
you guys go ahead and spend that extra money, but just to shed some light.
Here's a 94 prelude crank # part number
http://www.slhondaparts.com/br...A-000
and here's the 95 accord crank # number
Old Mar 16, 2004 | 05:14 AM
see...the crank i will sell you is much much cheaper than those. You can always buy a used one for less!
Old Mar 17, 2004 | 01:33 PM
confusion5's Avatar
do you have a h23 crank pulley also?
Old Mar 17, 2004 | 02:49 PM
LudeyKrus's Avatar
Default Re: 92-93 lude si motor crank question (confusion5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confusion5 &raquo;</TD></TR><TR><TD CLASS="quote">do you have a h23 crank pulley also? </TD></TR></TABLE>
I do! I do!
PM me if you need one, i'll let it go cheap.
carlossolorzano
May 30, 2012 06:43 AM
dallasyoung
Nov 2, 2011 04:53 PM
jbrokos307
13
Oct 21, 2009 05:51 AM
xxmastermindxx
Jun 14, 2007 03:05 PM
hondacrxhf_3
Jun 7, 2005 06:33 PM
