Tien SS or FLEX, upper mounts, drag q's
Old Mar 5, 2004 | 04:44 AM
SiRcyrusEH2's Avatar
Default Tien SS or FLEX, upper mounts, drag q's
I'm torn between tien ss or flex. Either way im going to get more streetable springs from tein, softer springs, I will rock the stock stiffies when im at the track. Tien does make them, but where do you buy them, anyone else every done this. My fear is that even with soft spring rates ill still have a bouncy ride. With flex do you still need camber kit, what about SS with upper pillow ball mounts do you need a camber kit for that. Where can i get the upper mounts. Im mainly a drager but i like to handle too, does tein suck for dragin.
Old Mar 5, 2004 | 11:49 AM
Default Re: Tien SS or FLEX, upper mounts, drag q's (SiRcyrusEH2)
any body have otehr ideas for around $1k suspension
Old Mar 5, 2004 | 12:05 PM
SloCivicHMM's Avatar
teins designs there spring rates according to the shock valving....
SS are 8k front and 6k rear rates
Flex is like 9k from and 6k rear for EG's.....
why would u want a softer spring??? I have SS and they are great for daily driving....****.......
for drag I wouldn't go TEIN...get GC's with a crazy rate.........12k front and 10k rear.....haha
Old Mar 5, 2004 | 12:19 PM
Blacklightning's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRcyrusEH2 &raquo;</TD></TR><TR><TD CLASS="quote">My fear is that even with soft spring rates ill still have a bouncy ride.</TD></TR></TABLE>
Springs don't make your ride bouncy, shocks are want control the bounce.
Old Mar 5, 2004 | 12:21 PM
Default Re: Tien SS or FLEX, upper mounts, drag q's (Blacklightning)
very true I forgot to mention that...
my SS ride great at mid range...if I put it at 16 all around holy **** do I bounce with every bump!!
Old Mar 5, 2004 | 12:34 PM
Default Re: Tien SS or FLEX, upper mounts, drag q's (SloCivicHMM)
then what do spring rates do just handling, couldnt i rock crazy rates with the teins
silverEH2's Avatar
id get the flex, by the time you buy the pillowball mounts for the SS its the same price as the flex and the flex come with pillowball mounts
Old Mar 5, 2004 | 12:41 PM
diearzte2
Guest
Posts: n/a
To answer your question about the camber kits... YES you still need camber kits. Civic suspension is not the style that is camber adjustable at the upper mount. I think ours is called McPherson or something like that, but I know it is the same as the 2g DSMs and they require seperate kits.
I run the Type Flex on my 97 Hatch. For camber: Skunk 2 Front, SPC Rear, and SRR LCAs
Old Mar 5, 2004 | 04:38 PM
Default Re: Tien SS or FLEX, upper mounts, drag q's (silverEH2)
well if the upper mounts dont effect cmaber whats the piont, and whats the piont of using softer spring rates, i under stand why to use stiffer in the front or stiffer in the rear, but overall
Old Mar 5, 2004 | 04:46 PM
ej one's Avatar
i bought the tein ss made for a dc4 .. that way i got stiffer spring rates without having to pay an extra $200 for custom spring rates from tein
Old Mar 5, 2004 | 04:59 PM
diearzte2
Guest
Posts: n/a
Default Re: Tien SS or FLEX, upper mounts, drag q's (black_ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_ej1 &raquo;</TD></TR><TR><TD CLASS="quote">i bought the tein ss made for a dc4 .. that way i got stiffer spring rates without having to pay an extra $200 for custom spring rates from tein</TD></TR></TABLE>
dc4?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRcyrusEH2 &raquo;</TD></TR><TR><TD CLASS="quote">well if the upper mounts dont effect cmaber whats the piont, and whats the piont of using softer spring rates, i under stand why to use stiffer in the front or stiffer in the rear, but overall</TD></TR></TABLE>
What do you mean "what is the point"?
Old Mar 6, 2004 | 03:03 AM
Default Re: Tien SS or FLEX, upper mounts, drag q's (diearzte2)
what do stiffer spring rates do, if it makes it stiffer wouldnt it make the ride worse....dc4 is a non gsr or type r usdm integra if im not mistaken
B R Speed Star
Suspension & Brakes
14
Dec 4, 2008 03:46 PM
Jbur074
Jan 2, 2008 07:53 PM
EBPSI
Suspension & Brakes
12
Feb 27, 2006 08:32 AM
carbonfibersi
Suspension & Brakes
Feb 20, 2005 06:56 PM
Asahi
Jan 15, 2003 09:24 PM
