stock tach accuracy.
Old Mar 4, 2004 | 09:34 PM
uNF$@#!'s Avatar
Default stock tach accuracy.
a major problem with the dc2 and EK models was that the stock tach being very inaccurate at higher RPMs.
for instance, a 9500 indicated on the tach was an actual ~8400
do the new dc5/ep3's also have this trait? i noticed in a lot of videos i see in cabin the owners are not shifting beyond a indicated redline.
Old Mar 4, 2004 | 09:39 PM
Blue_Si03's Avatar
Default Re: stock tach accuracy. (Soup ****)
It's not that bad in the EP3. At exactly 7000 it's actually 6800.
Old Mar 4, 2004 | 11:48 PM
pints99's Avatar
It's not the greatest up top. People who redline with hondata in a type S(redline should be 8600 with hondata) have seen it get up to lke 8800.
Old Mar 5, 2004 | 01:28 AM
eg_nezay's Avatar
Seems like the higher it goes the less accurate it becomes.
At 8100 on the tach, its actually 7700.
Someday, someone can tell you what its really at when it hits 9500rpm.
Old Mar 5, 2004 | 04:36 AM
schuessler28's Avatar
with my toda kit, the tach will go past the 9k before it bounces off the limiter. IF the tach numbers kept goin, it'd probably read like 9200rpm
Old Mar 6, 2004 | 07:54 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">a major problem with the dc2 and EK models was that the stock tach being very inaccurate at higher RPMs.
for instance, a 9500 indicated on the tach was an actual ~8400</TD></TR></TABLE>
I've never heard of a stock Honda tachometer being off by that much. That's some horrible exaggeration.
The normal variance is around 200-300 RPM.
Old Mar 8, 2004 | 11:09 AM
GreenBean's Avatar
Default Re: stock tach accuracy. (Targa250R)
That does make me wonder, I had a downshift that was a little to tall for the speed. Thankfully I was at @80 or so, I don't recall and downshifted into fourth...then went into third gear. Well when I did the tach went clearly to 8,400 rpms...Scared the absolute crap out of me(over-rev anyone) well the engine was fine but I was wondering why the ecu did not throw an engine over speed condition code. I was told that once I go past fuel cut it should code. Anyway...The 03 models do benefit from a single valve spring design...And I need more driving experience
If the tach is off that much in the higher rpms then maybe I didn't rev mine as high as I thought.
Old Mar 8, 2004 | 11:28 AM
Targa250R's Avatar
be professional
Default Re: stock tach accuracy. (GreenBean)
If you were at 80mph with the stock 205/55-16 tires, a downshift into 3rd would only spin the engine to 7200 RPM.
8400 RPM in 3rd is 93mph.
Old Mar 8, 2004 | 12:34 PM
GreenBean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">If you were at 80mph with the stock 205/55-16 tires, a downshift into 3rd would only spin the engine to 7200 RPM.
8400 RPM in 3rd is 93mph.</TD></TR></TABLE>
Thanks, I really didn't know the speed....I was on I-95 North in VA and traffic was going crazy fast...I was negotiating a hole with a soccer-mom in a Ford Explorer(POS)
Old May 28, 2009 | 08:17 AM
stalyun's Avatar
so does the car read off of the the stock tachometer for its redline?
Old May 30, 2009 | 10:11 AM
square_1's Avatar
Yeah... 3rd gear tops out just about exactly at 80 MPH so a downshift from 4th to 3rd would just top out third gear and maybe go slightly over.
I know that EP3 fuel cut is 7100 I believe and when my car hits fuel cut it is almost always just about at 7100. There are a couple times it has revved to 7500 and one time it said almost 8000 but that could have just been slight inaccuracy.
I would be it is pretty accurate.
Old May 30, 2009 | 10:17 AM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
even my EG is off, I shift at 9400 and it goes wayyy past that before it hits the redline, as much as i hate aftermarket tachs, there the way to go!
Old May 30, 2009 | 04:37 PM
tweek_boii's Avatar
after market tachs are more accurate ?
JuggerNuts
Jun 18, 2006 07:35 PM
TheBestCRX
18
Apr 8, 2006 10:01 AM
Beezle
Nov 2, 2004 10:33 AM
SleepnCiViC
14
Jan 16, 2004 05:46 PM
