ITR shock bushings better than other teg's? Part #'s ? bumpstops?
Old Oct 16, 2001 | 12:32 PM
Disco Monkey's Avatar
Default ITR shock bushings better than other teg's? Part #'s ? bumpstops?
i need to replace my shock bushings on my gsr. i think i remember hearing that the itr shock bushings are stiffer than the gsr's, is this true? anyone know if the will work on a gsr? anyone have the part #'s for the shock bushings? also i need to replace the bumpstops, are the bumpstops the same alsoor better and will the work? thanks for the help.
Old Oct 16, 2001 | 03:58 PM
Default Re: ITR shock bushings better than other teg's? Part #'s ? bumpstops? (Disco Monkey)
someone must know????
Old Oct 16, 2001 | 04:47 PM
PiYoImuT's Avatar
I donn't know if it is better...
but I am replacing mine with Spoons...
Old Oct 16, 2001 | 05:43 PM
BoM's Avatar
BoM
Default Re: ITR shock bushings better than other teg's? Part #'s ? bumpstops? (PiYoImuT)
bushings are bushings, either their rubber or some polyurethane...and all the teg's busshing get f^%*ed up! especially rear lower control arms
Old Oct 16, 2001 | 05:46 PM
Warren's Avatar
Wrong-Way Wang
The stock ITR shock bushings are very good. They're metal backed rubber, and the only bad thing about them is that the rubber part doesn't completely fill the gap. Definately stiffer than polyurethane bushings. You need to go to pillowmounts to improve. I'm happy with the stock ones.
Warren
Old Oct 16, 2001 | 05:51 PM
warren any idea if they are the same between the gsr and type r?
Old Oct 16, 2001 | 06:05 PM
B18CXr's Avatar
GSR and R bushings are NOT the same!
Old Oct 16, 2001 | 07:05 PM
ok then if they are not the same will the itr bushings work on my gsr?
thanks
PatrickGSR94
Suspension & Brakes
11
Jan 27, 2015 07:09 AM
PatrickGSR94
Apr 17, 2009 05:42 AM
gsxr
Oct 25, 2002 04:02 AM
Vitt1
Jul 19, 2002 04:10 PM
miketegra
Oct 19, 2001 09:13 PM
