Is Pillowball worth it?
Old Mar 4, 2004 | 07:18 PM
SuperSlow's Avatar
Default Is Pillowball worth it?
Are pillowball upper mounts (TEIN) worth the money? Does anybody have experience before and after? I have been thinking about getting teins. Anyone have flex or HA? What is the difference (Ihave seen both listed at about the same price)?
Old Mar 5, 2004 | 01:01 AM
@ries's Avatar
Default Re: Is Pillowball worth it? (SuperSlow)
I have the TEIN HA's with upper pillow-ball mounts. Not only did I notice that my wallet was significantly lighter... I did notice that my suspension felt stiffer and more responsive.
Old Mar 5, 2004 | 01:12 AM
ATS*Mark's Avatar
OG triple OG
Default Re: Is Pillowball worth it? (emoBB1)
if you look at it the right way thats two good things...
lighter wallet = faster speeds cause of weight savings when its in your car
stiffer suspension = i dont need to explain
Old Mar 5, 2004 | 07:01 AM
CleanLude's Avatar
In addition...i got more cabin noise from all the squeeking sounds...
Old Mar 5, 2004 | 07:46 AM
SuperSlow's Avatar
Default Re: (CleanLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLude &raquo;</TD></TR><TR><TD CLASS="quote">In addition...i got more cabin noise from all the squeeking sounds...</TD></TR></TABLE>
You got more cabin noise? from the mounts? or from bushing? please explain...
Old Mar 5, 2004 | 07:47 AM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emoBB1 &raquo;</TD></TR><TR><TD CLASS="quote">I have the TEIN HA's with upper pillow-ball mounts. Not only did I notice that my wallet was significantly lighter... I did notice that my suspension felt stiffer and more responsive.</TD></TR></TABLE>
Where did you get your HA's. How are they different from flex?
Thanks.
Old Mar 5, 2004 | 11:25 AM
bad-monkey's Avatar
Default Re: (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">
they come from the mounts, as it's basically metal to metal contact with pillowballs. means there's less give in the suspension but you also have to live with some discomfort (noises, more rigid, etc)
the diff between the HA and the FLEX are: different spring rates, FLEX are teflon coated to resist chipping and rust, FLEX is designed to make ride height independent from suspension travel, and the HA is discontinued. there are more differences i'm sure but i think those are the major ones.
Old Mar 5, 2004 | 04:22 PM
TimeRacer's Avatar
Default Re: (bad-monkey)
With the double wishbone suspension that comes on the majoirity of the Hondas the pillowballs are not weight bearing what-so-ever. I have the pillowballs and wish that I didn't since they'll really will do nothing w/o a full metal spherical bearing across the board and stiffen up the entire suspension.
Read more info here:
https://honda-tech.com/zerothread?id=758635
https://honda-tech.com/zerothread?id=482989
Old Mar 5, 2004 | 04:36 PM
SuperSlow's Avatar
Default Re: (TimeRacer)
Thanks. Great info. I should have thought to search there.
Old Mar 5, 2004 | 11:38 PM
@ries's Avatar
Thanks.</TD></TR></TABLE> I got them from Area 51 before they moved they relocated.
How are they different from flex?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">
the diff between the HA and the FLEX are: different spring rates, FLEX are teflon coated to resist chipping and rust, FLEX is designed to make ride height independent from suspension travel, and the HA is discontinued. there are more differences i'm sure but i think those are the major ones.</TD></TR></TABLE>
typeonespirit
Mar 25, 2007 10:07 PM
BB4-Japanpower
Jan 23, 2006 11:43 AM
jdmeg9
Sep 15, 2005 02:46 AM
azn98R
Jan 20, 2003 02:11 PM
TypeR 1159
Jul 12, 2001 04:29 PM
