replacing clutch on 1.5 SOHC QUESTION ???
Old Mar 4, 2004 | 07:14 PM
93FastLs's Avatar
Default replacing clutch on 1.5 SOHC QUESTION ???
How many bolts are there holding the transmission to the block ? and also what happens if you dont recut the flywheel ? and were there any other right ups on doing a clutch on this type of motor ? thanks..
Old Mar 7, 2004 | 07:43 PM
93FastLs's Avatar
up
Old Mar 8, 2004 | 11:32 AM
BauleyCivic's Avatar
Risky Business
Default Re: (93FastLs)
I'm gonna be doing a clutch in the next two weeks...here's my writeup on removing the tranny, I will have a clutch install thread soon.
https://honda-tech.com/zerothread?id=596873
Old Mar 8, 2004 | 01:51 PM
dfoxengr's Avatar
Default Re: replacing clutch on 1.5 SOHC QUESTION ??? (93FastLs)
6 bolts on d series, 8 on b series holding it to the block. recut, you mean resurface, you dont have to, but its a good idea, i just use an air die grinder with one of those sanding pads, a few times arounf the flywheel surface, or a metl wire cup brush on my 4.5" angle grinder.
Old Mar 8, 2004 | 02:01 PM
rob d's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93FastLs &raquo;</TD></TR><TR><TD CLASS="quote"> also what happens if you dont recut the flywheel ? </TD></TR></TABLE>
Your clutch wont last as long. Just get it resurfaced. Its about $40.
leondx
Apr 5, 2010 06:19 AM
GSR_hatch936
37
Nov 1, 2007 06:21 PM
TurboSI66
Mar 28, 2005 05:31 PM
integraautox
Jan 23, 2003 01:14 PM
