Pcv valve on b16
Old Mar 4, 2004 | 01:40 PM
NINJASPY's Avatar
Default Pcv valve on b16
the pcv valve on my b16 has nothing connected to it, on the other side of the intake manifold its bare.... so its just sucking in air under the intake manifold...
where does the pcv connect from under the intake manifold? Its really tight behind there so I cant really take a look. If anyone has any pics or knows what parts I need to fix/replace parts that I am missing it would be grrreat!
Old Mar 4, 2004 | 01:42 PM
RedlinedVTEC's Avatar
Default Re: Pcv valve on b16 (NINJASPY)
Connects to the oil seperator box on the back of the block.
Old Mar 4, 2004 | 01:53 PM
NINJASPY's Avatar
Default Re: Pcv valve on b16 (RedlinedVTEC)
what kind of lines/hoses do I need/should use?
Old Mar 4, 2004 | 02:59 PM
Regular vacuum line will work fine.
2lobes1engine
May 12, 2004 07:56 PM
NINJASPY
Aug 27, 2003 12:04 AM
keebler65
Jan 27, 2003 09:48 PM
EVOCELICA
Nov 2, 2002 07:33 PM
