Help! Last minute quik questions.. Where does the vacum hose coming off the top of the wastegate go
Old Oct 16, 2001 | 09:32 AM
chuckd05's Avatar
New User
Default Help! Last minute quik questions.. Where does the vacum hose coming off the top of the wastegate go
WHere does the vacum hose coming off the top of the wastegate go to?
Also what is the proper installation for the fuel pump that comes with the drag III kit? Is it supoised to only come on when boosting or does it replace the stock one?
Old Oct 16, 2001 | 09:43 AM
LEON's Avatar
Default Re: Help! Last minute quik questions.. Where does the vacum hose coming off the top of the wastegate
The top of the wastegate connects to a boost controler if you are running one. If you are letting the wastegate regulate boost, then leave it open.
If you received the Airtex pump that came with the DRAG GEN III kit, then it should be used in conjunction with your stock fuel pump, ie. run it in-line. The in-line pump should prime upone start up and work at all times.
MackSpeed-616
Sep 12, 2001 11:25 AM
tsjag17
Jul 22, 2001 06:11 PM
CrAZyRaCeR
Jul 21, 2001 09:54 AM
