Exactly how many qt of ATF does a 97 LX need?
Old Mar 4, 2004 | 12:42 PM
RedGSR's Avatar
Default Exactly how many qt of ATF does a 97 LX need?
I need to know how many quart to put in to the auto tranny. I already bought 3 qt from Honda, but I'm sure I don't need to fill it up with 3 quarts on drain/refill, correct?
Old Mar 4, 2004 | 12:46 PM
976's Avatar
976
New User
Default Re: Exactly how many qt of ATF does a 97 LX need? (RedGSR)
2.3 on refill...
This is most accurate, make sure car is level, fill until fluid pours out of the fill hole, once this is done it means you should not fill anymore, just plug. That simple.
Old Mar 4, 2004 | 12:53 PM
dantastic's Avatar
Default Re: Exactly how many qt of ATF does a 97 LX need? (976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 &raquo;</TD></TR><TR><TD CLASS="quote">2.3 on refill...
This is most accurate, make sure car is level, fill until fluid pours out of the fill hole, once this is done it means you should not fill anymore, just plug. That simple.</TD></TR></TABLE>
umm. that's for MTF isnt it? auto trannys have dip sticks to measure how much fluid is in there, but i dont know the capacity. give ur dealer a call, or just ask at the parts counter at the local autoparts store
Old Mar 4, 2004 | 01:00 PM
dpw41285's Avatar
Default Re: Exactly how many qt of ATF does a 97 LX need? (dantastic)
i thought it was 3, but thats what a DIPSTICKS for DIPSTICK.
Old Mar 4, 2004 | 01:19 PM
vtecb20coupe's Avatar
B A N N E D
the fill hole? not accurate. between 2-3 quarts, as long as the torque converter is completely full and has not been removed. just be sure to check the dipstick.
Old Mar 14, 2004 | 07:00 PM
91b18c5's Avatar
Default Re: Exactly how many qt of ATF does a 97 LX need? (vtecb20coupe)
I just done a 97EX today but it spill out 4qt, why?
poland accord
Mar 28, 2008 02:21 PM
garrybloom
Dec 12, 2005 04:16 PM
rasta420
Acura TL, RL & ZDX
Dec 2, 2003 10:57 PM
rex03
Sep 30, 2003 09:30 PM
Platoon918
Apr 25, 2003 12:45 PM
