Exhaust header studs x3 for lower header section
Old Mar 4, 2004 | 12:32 PM
OTT's Avatar
OTT
Default Exhaust header studs x3 for lower header section
How do you remove these? do you hammer them up to remove then literally bang the new ones in downwards? My car sounds like its open piped!
Old Mar 4, 2004 | 12:40 PM
Speedra500's Avatar
Default Re: Exhaust header studs x3 for lower header section (OTT)
are you talking about the section where the top header section connects to the A-pipe? because you just unscrew them...
Old Mar 4, 2004 | 12:44 PM
Daboi630's Avatar
Default Re: Exhaust header studs x3 for lower header section (Speedra500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 &raquo;</TD></TR><TR><TD CLASS="quote">are you talking about the section where the top header section connects to the A-pipe? because you just unscrew them...</TD></TR></TABLE>
yup, when i took off my DC to install the JDM one i was missing one of those.
Old Mar 4, 2004 | 12:50 PM
@ries's Avatar
If you're having a hard time unscrewing them just spray some WD-40 or Liquid Wrench on them and let it soak in.
Old Mar 4, 2004 | 01:02 PM
OTT's Avatar
OTT
Unsrew which way if you are looking at the threaded side?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emoBB1 &raquo;</TD></TR><TR><TD CLASS="quote">If you're having a hard time unscrewing them just spray some WD-40 or Liquid Wrench on them and let it soak in.</TD></TR></TABLE>
The threads broke on 2 of mine when i 'broke' the nuts off to remove the lower section
Old Mar 4, 2004 | 02:36 PM
Daboi630's Avatar
unscrew it the same way you would unscrew the nut.
my nut was stuck to my stud and it took the stud out
Old Mar 4, 2004 | 03:31 PM
Prelude Styl's Avatar
Default Re: (Daboi630)
yeah I've been there before man (broke stud when trying to take off the nut). You gotta use a bolt extractor to get them out.
Old Mar 4, 2004 | 04:13 PM
OTT's Avatar
OTT
ok gonna unscrew the three of them tomorrow, it didnt take out the stud justriped te threadsoff on two of them. Going back to the honda dealership tomorrow for the parts
Old Mar 4, 2004 | 04:34 PM
JG Luder's Avatar
Default Re: (OTT)
if it's still stuck hit up a machine shop.
coolgsrguy
Mar 26, 2006 12:17 AM
db8gsr_teg
Mar 16, 2006 10:05 AM
edo
May 11, 2005 09:18 AM
SpoonFedHatch
Apr 26, 2004 02:34 PM
civic91
Sep 9, 2003 02:00 PM
