Differential interchangable?
Old Mar 4, 2004 | 10:19 AM
mattssi's Avatar
Default Differential interchangable?
My diff for 99-00 si tranny is way messed up, and i am looking into a new one, But what i wanted to know was what are the interchangable diffs for this tranny? I have searched through recent and archived material and havent found solid info?
Old Mar 4, 2004 | 10:28 AM
Spartanic's Avatar
Default Re: Differential interchangable? (mattssi)
There are perforamnce LSD's that you can buy for your B16A such as Cusco, Kaaz, Quaife and ATS. You can find them all at http://www.jdmgears.com.
Old Mar 4, 2004 | 10:30 AM
mattssi's Avatar
I was looking for stock replacements, and years and types of trannies that it would interchange?
Old Mar 4, 2004 | 10:48 AM
mattssi's Avatar
Default Re: (mattssi)
Old Mar 4, 2004 | 10:58 AM
fearless_dsm's Avatar
i think you can use any 92-00 differential as long as you use the ring off of your diff.....gsr,ls,typer,del sol vtec....
Old Mar 4, 2004 | 10:59 AM
mattssi's Avatar
Basically i want to know if a 92 ls diff will work in a 99-00 si tranny?
Default Re: Differential interchangable? (fearless_dsm)
any 92-00 b series diff...
Old Mar 4, 2004 | 11:00 AM
yea the LS diff should work as long as you use the ring gear off of your diff..
Old Mar 4, 2004 | 11:08 AM
mattssi's Avatar
Anybody want to confirm this before i make a purchase?
Old Mar 4, 2004 | 02:50 PM
torr's Avatar
ls and si are a straight swap
gsr and type r are a straight swap
you can put a type r diff on a si but i believe you have to change some gears, i can't remember but something like speedo gear or ring gear, something like that. same thing goes for gsr and ls.
pretty much they're all interchangeable but going from si to gsr, type r or vice versa requires changing gears.
Zac W.
Feb 17, 2012 06:09 AM
tony n.
Jul 26, 2005 10:05 PM
Lightning Orders
Jan 14, 2004 06:29 PM
Mr.DC2TurBo
Jul 24, 2003 05:45 PM
Mr.DC2TurBo
Jul 23, 2003 04:02 PM
