head problem
Old Mar 4, 2004 | 09:10 AM
zbower7's Avatar
Default head problem
heres what happen when i was undoing the head bolts all came but one. this it slipped. and the socket just kept spinning on it. can a michine shop cut it out. i sure hope so because i need to get that head off. somebody tell me what to do
Old Mar 4, 2004 | 09:14 AM
florduhdude's Avatar
Default Re: head problem (zbower7)
It sounds like it stripped out the threads. These are in the block and that's not going to be an easy fix. You said you have all the other ones out, so you should be able to break the seal between the head and block and pull up on the head while turning the stripped head bolt. This should get it out but it won't fix the problem obviously.
Old Mar 4, 2004 | 09:23 AM
zbower7's Avatar
no the bolt it self isn't spinning the socket is spinning on the top of the bolt. the head of the bolt is stripped.
Old Mar 4, 2004 | 09:24 AM
zbower7's Avatar
help
Old Mar 4, 2004 | 09:25 AM
ThePro's Avatar
Ohhh!
Go to Sears and ask for a stripped screw and bolt puller and then go to town.
Think it's called Craftsmen Bolt-Out.
The non-craftsmen bolt puller blow.
Craftsmen
No-Name
Old Mar 4, 2004 | 09:35 AM
ThePro's Avatar
Default Re: (ThePro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zbower7 &raquo;</TD></TR><TR><TD CLASS="quote">the head of the bolt is stripped and the socket keeps spinning on the head bolt. it just won't budge. what is the craftsman bolt out stuff will it possible get this head bolt out or will i have to take it to a michine shop</TD></TR></TABLE>
Since your other post is going to take about 5 minutes for one of the mods to delete it I'll post the responce here.
I'd give the bolt out a try. It's only like $20 or something. Then you have a new tool as well.
https://honda-tech.com/zerothread?id=784184 has some info on it as well.
Modified by ThePro at 10:53 AM 3/4/2004
bow tie
Nov 15, 2008 05:11 PM
1991hb
Aug 13, 2007 12:44 PM
Serdar
Aug 18, 2006 11:39 PM
Hondaholik
Jul 24, 2006 02:31 PM
ltho1998
Aug 16, 2003 06:59 PM
