JDM fog light switch plug/harness
Old Oct 16, 2001 | 08:01 AM
GiFF's Avatar
Default JDM fog light switch plug/harness
i need to find the plug/harness to attach the jdm headlights w/ foglight, to the foglight switch i just bought... does anybody know the part # or where i can get that...
also i need the plug/harness to attach onto the main unit of the jdm headlights
Old Oct 16, 2001 | 08:07 AM
Rboosted717's Avatar
Default Re: JDM fog light switch plug/harness (G CHAN)
lol, sorry but not luck for those items. You just have to use spade connectors to harness plugs. It work great for me and everyone else who does the conversion. As for the foglight plug, try just shoving the wire into the little pin. Thats what I did.
Old Oct 16, 2001 | 08:12 AM
GiFF's Avatar
Default Re: JDM fog light switch plug/harness (Rboosted717)
wouldn't integra's with foglight switch use that same harness/plug?
one more thing is ur foglight switch connected to another fuse?
Old Oct 16, 2001 | 08:14 AM
They use a different harness for the US fog switches.
For the fog's power I just used the headlight wires and power since I'm using my HID's which get their own power. The downside was that I currently have to have the headlights on to use the foglights since they use the stock headlight power. Still not bad though and they will never blow a fuse because the fogs are lower power then the stock headlight power.
Old Oct 16, 2001 | 08:22 AM
GiFF's Avatar
how do i tell if my fog light switch is JDM or USDM????
Old Oct 16, 2001 | 08:25 AM
sackdz's Avatar
I got an extra harness
Old Oct 16, 2001 | 08:27 AM
GiFF's Avatar
Default Re: JDM fog light switch plug/harness (sackdz)
harness for the headlights? or foglights?
Old Oct 16, 2001 | 08:29 AM
sackdz's Avatar
fogs
Old Oct 16, 2001 | 08:31 AM
GiFF's Avatar
how would i know it will fit my fog light switch?
because rboosted said there's a difference between JDM and USDM
now i'm unsure if i have th JDM or USDM fog light switch...
Old Oct 16, 2001 | 08:35 AM
BDiddy's Avatar
USDM is on the center console and the JDM is where the Cruise control should be.
Old Oct 16, 2001 | 08:37 AM
GiFF's Avatar
Default Re: JDM fog light switch plug/harness (B-DIDDYR2K)
just found out... i have the JDM plug switch... sackdz so do u have the harness for the JDM plug? that hooks up to the fogs on the JDM headlights?
Dipshit Dan's Avatar
Cruise plug on USDM cars is same as JDM fog light plug
Old Oct 16, 2001 | 08:44 AM
sackdz's Avatar
I have the harness that runs under the radiator that the fogs plug into, that the itr does not have normally. it lpugs into a brown connector near the drivers side headlight, which leads inside the car to a wire of forgotten hue. maybe i didn't understand your question.
[Modified by sackdz, 12:46 PM 10/16/2001]
Old Oct 16, 2001 | 09:06 AM
GiFF's Avatar
ummm... dan just told me mine was the jdm fog light switch...
which can use the cruise control harness/plug on USDM integra... where the ITR'S don't have and have that empty space...
dunno if u're talking about that plug...
Old Oct 16, 2001 | 09:15 AM
Mike M's Avatar
Founding Member
Not all of us , I found a plug off of an Integra wiring harness that fits the JDM Headlights connector Just had to pull the pins and rewire a bit (I'm picky)
As far as the Fog Lamp Switch it uses the same plug as a Cruise control switch and the same as about 2 or 3 other plugs in the car. Go to a salvage yard
Old Oct 16, 2001 | 09:34 AM
hybrid_eg's Avatar
Default Re: JDM fog light switch plug/harness (TypeRmsm)
my friend.. they guy that does all the work on my car.. the master electrician heheh.. he just hotwired mine.. i didnt have time or money to go look for a harness.. so he made one.. took the fog switch apart.. bonded all the wires together made little connectors and it all works great! even when you take the switch out it looks so fresh and so clean.
Old Oct 16, 2001 | 09:35 AM
GiFF's Avatar
Default Re: JDM fog light switch plug/harness (hybrid_eg)
wonder if that friend can help me out... i'm located in socal too...
Old Oct 16, 2001 | 08:04 PM
koy's Avatar
koy
New User
i must agree ismar...Joe knows electrical stuff---i hear he's pretty good with motor work too---hey haven't i seen you over there late nights? some engine mods going on later...
Old Oct 17, 2001 | 12:25 AM
hybrid_eg's Avatar
Default Re: JDM fog light switch plug/harness (koy)
all my shieze is on hehehe... looking so fresh and so clean afterall! we gotta meet up and take some pics! no work done under my hood though.. no more $$.. really broke right now..
werteg
Jan 4, 2011 08:36 PM
Benjithx
Feb 7, 2005 11:49 AM
kotetu
Apr 30, 2004 05:40 AM
