Maintenance required indicator is RED, 91 Accord
Old Mar 4, 2004 | 08:00 AM
ccombs's Avatar
Default Maintenance required indicator is RED, 91 Accord, HELP #%*! :(
I purchased my car about 5 months ago, when I bought it the maintenance required indicator was green (not a light, seems like a little wheel??) I was fine with that, then about a month ago it turned yellow, okay now I'm a bit more nervous. My car does have 175,000 miles??? And now this morning it turned RED, now I'm freak'n, car seems to run just the same..........just want to know I am not going to blow any input would be greatful. Thanks, Christine
Old Mar 4, 2004 | 08:18 AM
The_Todd's Avatar
Farts in the shower
Default Re: Maintenance required indicator is RED, 91 Accord, HELP #%*! :( (ccombs)
Search but here ya go:
https://honda-tech.com/zerothread?id=382385
https://honda-tech.com/zerothread?id=102032
https://honda-tech.com/zerothread?id=219139
The most important thing you will use on H-T
https://honda-tech.com/zerothread?id=749544
Old Mar 4, 2004 | 10:35 AM
fw190bvi's Avatar
Default Re: Maintenance required indicator is RED, 91 Accord, HELP #%*! :( (VRDrvr)
LOL.......this comes up once a month.......just put ur key into that slot in teh gauge cluster, and it should reset it......in case u were too lazy to click on the links: its some sort of wheel thing that goes green-yellow-red.........it should go red every 15k (i think) and its supposed to idicate that its time for regularly scheduled maintence
300th post bitches
Old Mar 4, 2004 | 12:28 PM
AznPrideYo's Avatar
Default Re: Maintenance required indicator is RED, 91 Accord, HELP #%*! :( (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">300th post bitches</TD></TR></TABLE>
LOL!
BTW I wouldn't really freak out with cars just read the manual and if it doesn't tell you anything then ask here and if H-T tells you you need to look for a new engine/ car or whatnot then you can freak.
Old Mar 4, 2004 | 04:25 PM
blondeaccord's Avatar
Default Re: Maintenance required indicator is RED, 91 Accord, HELP #%*! :( (AznPrideYo)
In my 93 the little "wheel" changed about every 5000 miles. I am pretty sure that it is reminding you to get an oil change. I changed my oil every 3000 miles. So I just put my key in every time I got an oil change.
Old Mar 4, 2004 | 08:41 PM
jwogen1's Avatar
Default Re: Maintenance required indicator is RED, 91 Accord, HELP #%*! :( (blondeaccord)
in 5th gens it turns red when you pass 7500miles since it was last reset by yourself or mechanic. just a reminder.
Rbk
Paint and Body
Nov 3, 2009 10:10 AM
v_dub_ya
Jun 26, 2006 06:52 PM
dumpling101
Jan 25, 2006 06:47 AM
