possible bad gas and additives?
Old Mar 4, 2004 | 07:19 AM
wickedEFguy's Avatar
Default possible bad gas and additives?
so my car has been sitting for almost 1.5 yrs now and it has half a tank of gas left since it last ran with the D16. I just swapped the B16 in and I'm a little worried to fire it up. Some ppl say that condensation could have happened at the top of the gas tank then fell and started rust. Others say my gas may have turned into sludge and won't start. I just did some research and that gas starts to deposits/varnish and loses it's volatility.
Ok now what I'm wanting to know is what is this "Dry gas" additive stuff that I keep on hearing about and if I should use this before I start up my car?
anything else you guys would recommend other then draining the gas tank and filling it back up with premium?
Old Mar 4, 2004 | 07:55 AM
timmy8151's Avatar
Default Re: possible bad gas and additives? (wicked B16)
If your car has been sitting that long, the safest thing you could do would be to drain the gas tank. Fuel additives like Sta-bil and etc might work, but should of been used before the car was put in storage.
Old Mar 4, 2004 | 08:06 AM
Default Re: possible bad gas and additives? (timmy8151)
thanx for the advice
Old Mar 4, 2004 | 10:38 AM
Spartanic's Avatar
Defintly drain the gas tank and remove the old stuff, clean it out good.
pepsi813
Honda CR-V & Element
May 19, 2019 12:41 PM
ohsnapzafingcu
Dec 5, 2005 04:44 PM
ekdriven
Jun 8, 2004 08:39 AM
E-Rok
Dec 26, 2003 12:55 PM
SjCiViCHB
Feb 14, 2003 06:35 AM
