really low idle
Old Mar 4, 2004 | 06:41 AM
SwampThing's Avatar
Default really low idle
ok so i installed some 2 piece chikara headers but we threaded one of the bolts wrong so it doesnt go in all the way, so now i have an exhaust leak. i was wondering if this is what caused my really low idle once my car is warmed up. it idles at about 1500 when cold and drops to almost zero im guessing around 300 when warmed up. car is a 98 ex thanks.
Old Mar 4, 2004 | 06:43 AM
drewbie's Avatar
Default Re: really low idle (SwampThing)
it prolly can only idle at 400 at the least, thats how low my z6 goes when I am not driving the clutch right and coming off of a stop
maybe your IAC?
Old Mar 4, 2004 | 06:48 AM
SwampThing's Avatar
no it goes lower then that sometimes it drops to the line right above 0 and sounds like it's going to die. IAC?
Old Mar 5, 2004 | 04:40 AM
drewbie's Avatar
Default Re: (SwampThing)
IAC is your idle air control valvle. YOu need to check for a cel (check engine lite) code.
If you have a eg hatch or civic, there are 2 plugs where the ECU goes. One of them has 3 holes, the ohter has 2. (they are blue)
Stick a paper clip (1) in both the holes so the circuit can be completed.
Your SRS and CEL lites will start blinking. Count the number of times the cel lite blinks.
I think if it is a long blink, then that means 10. the quick blinks mean 1.
Old Mar 5, 2004 | 04:44 AM
95turbohatch's Avatar
After u check you IAC If thats not it,
Try your idle screw on your throttle body, located in the upppe left corner of the TB..
Does it serge from ilke 1000 down to 400??
If so prob IAC check it out like mr Teal said to do..
O and if u dont know where it located its locate on the back of your Intake manifold,
Its two 12 mm bolts and 2 coolant hoses..
Goodluck
Old Mar 5, 2004 | 05:37 AM
Filthy Focker!'s Avatar
Default Re: (95turbohatch)
Wait a minute... Was it doing this before you swapped the header?
vehicle
Oct 16, 2015 09:33 PM
travie_vtec
25
Feb 8, 2013 09:43 PM
pfsmith99
Oct 14, 2012 09:02 AM
jrhcivak
Mar 29, 2012 08:48 AM
92bseries
Dec 7, 2011 12:59 PM
