my 1st gen b16a will not stay running?
Old Mar 4, 2004 | 06:17 AM
HondaCivicSiR1's Avatar
Default my 1st gen b16a will not stay running?
it starts up fine and runs for about 2 mins then it bucks then shut off if anyone knows whats up with it please let me know thanks
Old Mar 4, 2004 | 07:17 AM
virginia_dude's Avatar
Default Re: my 1st gen b16a will not stay running? (HondaCivicSiR1)
Getting any error codes on ECU or Check engine before it dies?
Old Mar 4, 2004 | 08:35 AM
vtecb20coupe's Avatar
B A N N E D
what else is happening before this happens? like your rpms, oil pressure, etc?
Old Mar 4, 2004 | 10:38 AM
Default Re: my 1st gen b16a will not stay running? (virginia_dude)
no codes from the ecu. no check engine light
Old Mar 4, 2004 | 10:39 AM
Default Re: my 1st gen b16a will not stay running? (vtecb20coupe)
it bucks before it shut's off but that's all that does before it shut's off
Old Mar 4, 2004 | 10:53 AM
mattssi's Avatar
Check fuel filter! And this only happens when it gets warm?
Old Mar 4, 2004 | 11:10 AM
976's Avatar
976
New User
Default Re: my 1st gen b16a will not stay running? (mattssi)
It bucks?
Does it die while the gas pedal is ingaged?
When was the last time you did a tune up?
Old Mar 4, 2004 | 05:55 PM
i replaced the fuel filter 2 months ago
Old Mar 4, 2004 | 05:57 PM
Default Re: my 1st gen b16a will not stay running? (976)
my motor has 38 thousand miles on it and no to your other question a buddy of mine said to check the fuel pressure because he thinks it maybe the fuel pump?
Modified by HondaCivicSiR1 at 7:39 PM 3/5/2004
Modified by HondaCivicSiR1 at 7:40 PM 3/5/2004
Old Mar 5, 2004 | 04:19 AM
976's Avatar
976
New User
How many miles does the engine have on it?
Did you do a carbon build up cleaner, esp. around the t/b?
Old Mar 8, 2004 | 06:11 AM
i got my car to stay running last night.it was the ingtion module i cleaned the termanals and plugs and it run like a champ. but im going to replace the distubter so that this do not happen again thanks for trying to help me.
Witness327
Jun 20, 2015 06:16 AM
blk_eg4
Aug 3, 2006 08:27 PM
Sanj
Sep 10, 2005 07:52 PM
harryr34
Jun 7, 2005 01:23 PM
Cyrio
Aug 22, 2002 07:57 AM
