OE honda timing belt for a b18B the same as Type R?
Old Mar 4, 2004 | 05:14 AM
red civic standard's Avatar
Default OE honda timing belt for a b18B the same as Type R?
are they the same?
Modified by red civic standard at 7:58 AM 3/4/2004
Old Mar 4, 2004 | 07:09 AM
Dan GSR's Avatar
Default Re: OE honda timing belt for a b18B the same as Type R? (red civic standard)
no
B18C1 is the same
Old Mar 4, 2004 | 07:38 AM
ThePro's Avatar
I wouldn't think so because the VTEC heads are slightly taller (by about an inch or two) that the non-VTEC heads. So you need more belt to get to the cam gears.
Call Acura and find out. Ask for part numbers for both the b18b, b18c1 and b18c5
Old Mar 4, 2004 | 07:39 AM
Dan GSR's Avatar
Default Re: (ThePro)
acuatlly if u run a ls water pump, u can run ls timing belt
but thats stupid, the water will run too fast to cool properly
Old Mar 4, 2004 | 07:48 AM
Austin's Avatar
Default Re: (Dan GSR)
They're off by 1 tooth on the timing belt, one of them has 1 less tooth. I know because the dealership gave me the wrong one...glad that I found out before Chris and I tried to install it
Old Mar 4, 2004 | 10:17 AM
arw321's Avatar
Default Re: (Austin)
I believe they are off by 3 teeth. B VTEC water pumps have 19 teeth whereas LS pumps have 22, from what I can remember.
Honduh Tooner
May 23, 2005 04:10 PM
JdmH22Acorn
May 16, 2005 08:16 PM
EFOSV
Jun 16, 2004 07:22 PM
SPEED123
Feb 16, 2003 05:59 PM
dub204
Jun 6, 2002 09:09 AM
