Primary O2 Sensor Heater- Circuit Malfunction
Old Mar 3, 2004 | 08:03 PM
99spanishGT
Guest
Posts: n/a
Default Primary O2 Sensor Heater- Circuit Malfunction
Ok so i pulled up ecu code 41 which is supposely the primary O2 sensor heater. Is this right? where is it located? what does it do? its not the o2 sensor o the exhaust is it? check sig for car type. thanks for all your help!
Old Mar 3, 2004 | 08:07 PM
PrecisionH23a's Avatar
Default Re: Primary O2 Sensor Heater- Circuit Malfunction (spanishlude)
Yes, it is the 02 sensor in the exhaust. It is located on your exhaust below your oil filter.
Old Mar 3, 2004 | 08:09 PM
4bidden's Avatar
Yes it is the o2 sensor in your header.
Did you reuse your o2 sensor or was there one in that downpipe you bought that you used?
Old Mar 3, 2004 | 08:15 PM
poison's Avatar
Sounds like o2 is gone, or if you installed a header, installed it wrong.
Otherwise it's a wire prob.
SuperSlow's Avatar
I pulled a 41 and 43 and after fixing the an oil leak (gasket to oil sending unit) that was spilling onto the O2 sensor, I replaced the unit. Clear now. I think you can find replacements for under 100... good luck.
99spanishGT
Guest
Posts: n/a
Default Re: Primary O2 Sensor Heater- Circuit Malfunction (4bidden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">Yes it is the o2 sensor in your header.
Did you reuse your o2 sensor or was there one in that downpipe you bought that you used?</TD></TR></TABLE> i reused my old one. how much is a new one?
Old Mar 3, 2004 | 08:16 PM
4bidden's Avatar
Default Re: Primary O2 Sensor Heater- Circuit Malfunction (SuperSlow)
I got a spare 4 wire in my garage if you end up needing a new one.
Old Mar 3, 2004 | 08:19 PM
4bidden's Avatar
Lift the car up and check everything out first before you go buyin stuff.
Old Mar 4, 2004 | 12:22 AM
pentaq's Avatar
check a white wire going to the sensor
Phoenix_ITR
Jul 9, 2003 04:21 AM
