torque converter ?
ok, i just changed out my friends busted tranny and the car drives but has no power, the only thing i can think of is its the torque converter, i was wondering if a converter from a 93 ls teg can wrk because they look to be the same sized and the splines line up and fit and the bolt pattern looks the same. but i just wanna make sure before i try anything stupid.
PLz help would be appreciated
NO idea but the torque converter RARELY busts out, mostly is the Clutchpack that got abuse.
again check the atf, if it got little brown sand like stuffs in the juice, it's the clutchpack
Its more then likly the clutch packs like he said. But when you drive what do you mean it has no power? Slips, Flare shifts, bogs down. those all make a difference.
Check to make sure the shift siliniods are all plugged in correctly. Also check your fluid level. Just for S&G check to make sure you can turn the wheeels by hand when the car is in neu. on jack stants to see if its really binding inside.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed95Cord »</TD></TR><TR><TD CLASS="quote">Maybe he'd get his power back if you posted this in the RIGHT FORUM
what u mean ????? im asking this question for an accord. would a ls converter work in a ex?
</TD></TR></TABLE>what u mean ????? im asking this question for an accord. would a ls converter work in a ex?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">
what u mean ????? im asking this question for an accord. would a ls converter work in a ex?</TD></TR></TABLE>
Equals
<FONT COLOR="red"> pwnd </FONT>
On a side note....I wouldn't think a teg TC would work in a accord
</TD></TR></TABLE>+
Equals
no, you can use a h22 Tq, they share the same bolt pattern and will line and bolt up:
what did you do to the car? swap? or just replace tranny? check your fluids and do you have any CEL or D4 light flashing?
if your auto, remember the shift points are controlled only by your tcu if you odb1 and your ecu/tcu single unit if your obd2
well the reason i asked is both the converters are the same size, and the splines line up. im not an idiot for asking a question. i asked because it was only gonna be temp until we could get the H22 in it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed95Cord »</TD></TR><TR><TD CLASS="quote">first post never said anything about an accord, thats why i said that, im also not the idiot asking if a part from a teg tranny will fit an accord tranny, me pwnd? nope
i never said you were an idiot, i just thought that it could...i figure if most of hondas parts are interchangeable why not the converter.
BTW the clutch pack, is that in the converter?
</TD></TR></TABLE>i never said you were an idiot, i just thought that it could...i figure if most of hondas parts are interchangeable why not the converter.
bloobin
Aug 6, 2004 01:04 PM
