Integra Motor Mounts
Old Mar 3, 2004 | 07:29 PM
Justin95GSR's Avatar
Default Integra Motor Mounts
I have a JRSC on my car and i has thinking about getting some motor mounts. I found some for 39.95 for front two is that woth it. Or are those too cheap? Will that help not wheel hop as bad
Old Mar 3, 2004 | 07:32 PM
Kendall's Avatar
You mean motor mount inserts, or actual mounts. I think the actual durometer and material should be the deciding factor. Also consider the fact that adjusting your launching technique could solve the problem and not cost you anything.
Old Mar 3, 2004 | 08:07 PM
Spartanic's Avatar
Default Re: Integra Motor Mounts (Justin95GSR)
You can strenghtn the engine mounts with Energy Suspensions engine mount inserts (found at http://www.jdmgears.com). It will improve your lap times somewhat since it reduces the engine from violently rocking back and forth during shifting.
Old Mar 4, 2004 | 05:24 AM
Default Re: Integra Motor Mounts (Spartanic)
thanks for the info
Old Mar 4, 2004 | 08:37 AM
RedTegLS's Avatar
Chocolate milk should do a commercial by setting a bottle of it on the dash of a car with new poly motor mount inserts. "shake things up" It gets a little better after time.
Old Mar 4, 2004 | 11:25 AM
Creep's Avatar
Default Re: Integra Motor Mounts (RedTegLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote">Chocolate milk should do a commercial by setting a bottle of it on the dash of a car with new poly motor mount inserts. "shake things up" It gets a little better after time.</TD></TR></TABLE>
lol... acutally. in North America 'Chocolate milk' would never need to advertize.
Everyone here is fat.
integrawow
Suspension & Brakes
Nov 10, 2006 09:48 PM
george34
Dec 9, 2005 06:52 PM
Ls On StErIoDs
Oct 21, 2005 09:39 AM
hotdoggies
10
Mar 7, 2005 07:47 AM
Jamison
Mar 3, 2003 05:10 PM
