91 CRX: Do stock suspension springs get old?
Old Mar 3, 2004 | 04:28 PM
d15maverick's Avatar
Default 91 CRX: Do stock suspension springs get old?
Ive been riding around on blown shocks with the EIbach pro kit for some time now, and have been thinking about going back to stock spring and shock set up. I don't want to have to buy a camber correction kit, or performance shocks just regular ones to go with the stock springs. But my CRX is almost 13 years old and I am questioning how well the ride would be with new shocks on old springs. Should I invest in new springs before I get new shocks? Or do springs even get old? TIA
Old Mar 4, 2004 | 05:30 AM
smokinem's Avatar
Default Re: 91 CRX: Do stock suspension springs get old? (d15maverick)
the only way they get old is if the break or if there is any sign of rust on the spring
Old Mar 4, 2004 | 06:08 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: 91 CRX: Do stock suspension springs get old? (smokinem)
you can get rust on the spring if the protective caoting comes off. that doesn't necessarily mean it's old.
Old Mar 4, 2004 | 10:43 AM
Spartanic's Avatar
Even though the old springs are old and rusted they still wont break. The problem is that over time they get old and start sagging which makes your car sit a bit lower than stock.
Old Mar 4, 2004 | 11:01 AM
MightyMouseTech's Avatar
Default Re: 91 CRX: Do stock suspension springs get old? (Spartanic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spartanic &raquo;</TD></TR><TR><TD CLASS="quote">Even though the old springs are old and rusted they still wont break. The problem is that over time they get old and start sagging which makes your car sit a bit lower than stock.</TD></TR></TABLE>
Wont break? You obviously don't work on many Hondas. We keep a LARGE quantity of springs in stock to replace broken factory springs. It is VERY common to replace them.
And to add another point, springs DO NOT get softer, they will only sag as they age.
lngel
Suspension & Brakes
Aug 6, 2015 07:36 PM
Tong.Y
Suspension & Brakes
Nov 8, 2009 12:40 PM
B18IntegraLS
Jun 28, 2008 05:50 PM
deviant1
Jun 30, 2007 02:14 PM
vermilion
Suspension & Brakes
Aug 1, 2006 01:14 AM
