2nd gen cat-back question
Old Mar 3, 2004 | 04:00 PM
MYDA9's Avatar
Default 2nd gen cat-back question
What do I need to do, if i want to use my 90-91 cat-back on my 93 integra? I did a search but all i could come up with is they are different lengths?
thanks
Old Mar 3, 2004 | 04:03 PM
ljoe's Avatar
Default Re: 2nd gen cat-back question (ja90teg)
i believe all that's different is the cat itself, the length on that is different
Old Mar 3, 2004 | 05:36 PM
92AztecGsr's Avatar
You can buy an adapter piece have seen em before to make up for the shortness of the 90-91 exhaust systems, 92-93 is longer, I just unpacked my Rs*r ex mag tonight for my 90 ls
Old Mar 3, 2004 | 05:45 PM
Colin's Avatar
every part of the exhaust is different. The downpipe, the cat and the catback are all different. Thus you have to use all 3 pieces from the same (either 90-91 or 92-93).
so that adapter piece would only work if you are putting a 90-91 system on a 92-93 with stock length downpipe and cat.
Old Mar 4, 2004 | 06:17 AM
92AztecGsr's Avatar
Default Re: 2nd gen cat-back question (91IntegGS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91IntegGS &raquo;</TD></TR><TR><TD CLASS="quote">every part of the exhaust is different. The downpipe, the cat and the catback are all different. Thus you have to use all 3 pieces from the same (either 90-91 or 92-93).
so that adapter piece would only work if you are putting a 90-91 system on a 92-93 with stock length downpipe and cat.</TD></TR></TABLE>
Thats what I was implying to him 91gs
Old Mar 4, 2004 | 07:27 AM
MYDA9's Avatar
Default Re: 2nd gen cat-back question (92AztecGsr)
so just use everything off the 90, header, cat, and the rest of the exhaust....and just switch onto the 93. Will i have any obd issues?
thanks
Old Mar 4, 2004 | 09:53 AM
Colin's Avatar
you could swap all the parts from the 90, but the header isn't as good of a piece (doesn't flow quite as well) and the O2 sensor bung will be in the wrong place. You have to use the O2 sensor from the 93 and extend the wires. I'm not sure if the new placement of the sensor will have any illeffects though.
I personally think its a better idea to just get an adapter. that way you can keep the better exhaust manifold as well as have the O2 sensor in the correct location. I may try and purchase 92AztecGsr's RSR adapter since the adapter I have on my car is the wrong diameter. If I purchase his, I could sell you mine. It will be a little larger diameter than the stock piping, but would still work perfectly fine.
exare250
Jul 25, 2007 11:33 PM
alacard
May 9, 2006 02:26 PM
Cidone
Nov 15, 2004 08:24 AM
streetlegal gocart
Aug 29, 2004 08:39 AM
(__________)
Jan 20, 2003 02:13 AM
