Check engine Light on. PLZ help
Old Mar 3, 2004 | 03:46 PM
Awax223's Avatar
Default Check engine Light on. PLZ help
Well my check engine light came on yesterday so i took it to auto zone to get it hooked up to a cpu to find the problem. This is what they told me to write down and show it to someone at the Honda dealership:
P1259
Immobilizer to PCM Signal error
Does anyone know what this means?
Old Mar 3, 2004 | 05:50 PM
Awax223's Avatar
Default Re: Check engine Light on. PLZ help (Awax223)
ttt
Old Mar 3, 2004 | 06:43 PM
poison's Avatar
wtf? did they give you a code number?
describe your car too. info info..
Old Mar 3, 2004 | 07:21 PM
Turbogixxer's Avatar
Default Re: Check engine Light on. PLZ help (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">wtf? did they give you a code number?
describe your car too. info info..</TD></TR></TABLE>
It looks like from a scanner and OBD2
Old Mar 3, 2004 | 07:28 PM
Awax223's Avatar
o sry my car is a 97 EX and it is all stock.
Old Mar 3, 2004 | 07:49 PM
poison's Avatar
Did they give u a code number at all? Should be a 1 or 2 digit code
Old Mar 3, 2004 | 08:17 PM
Awax223's Avatar
nope just this P1259.
Old Mar 4, 2004 | 12:43 AM
kwil6666's Avatar
P1259
that is the code, thats what the code looks like when its from a scanner. if you look inside a manual it will say the codes and what they mean. sorry i cant be much more help im at work and dont have any info here.
keith
Old Mar 4, 2004 | 05:26 AM
EE_Chris's Avatar
Default Re: Check engine Light on. PLZ help (kwil6666)
Just to clear it up: "P" codes are specific to OBD2...and "P1" indicates a manufacturer specific code.
And you have a totally stock 97 Ex....I thought only Teg's came equipped with immobilizers???
Old Mar 4, 2004 | 05:31 PM
Awax223's Avatar
Default Re: Check engine Light on. PLZ help (EE_Chris)
Hmmm that is weird? I bought the car from some mom and pop dealership for 3k, so maybe the did some **** to the car?
Old Mar 4, 2004 | 06:34 PM
Chiovnidca's Avatar
p1259 = VTEC system malfunction
Old Mar 4, 2004 | 06:49 PM
Awax223's Avatar
Default Re: Check engine Light on. PLZ help (Chiovnidca)
cool Thanks! what do i have to do to fix it? DO i need to buy a new Manifold?
Old Mar 4, 2004 | 07:02 PM
poison's Avatar
No, sounds like the vtec solenoid is either not connected, or is a bad solenoid.
Jump the solenoid by taking a piece of wire and putting 12v volt to the solenoid. It should click. If it does, you have a wiring problem or bad connection. If it doesn't click, then the solenoid will need to be replaced.
Old Mar 4, 2004 | 07:07 PM
Awax223's Avatar
cool Thanks a lot guys! Is there a write up anywhere for this i can look at by any chance?
Old Mar 4, 2004 | 08:11 PM
poison's Avatar
A Helms manual will explain troubleshooting. Other than that, it's cake.
Old Mar 5, 2004 | 07:53 PM
Awax223's Avatar
Thanks for the info again fellas. I tested and cleaned the solenoid and now my CEL is off and my Vtec is back!
ddevault1
Honda CR-V & Element
May 31, 2015 02:26 PM
civic-4-ges
Jan 24, 2004 08:28 AM
thehondaguru
Nov 23, 2003 07:38 AM
IgniteTeg
Aug 8, 2002 09:26 AM
IgniteTeg
Aug 7, 2002 06:54 PM
