should i save my fidanza flywheel? need help.
ok... to make a long story short.. the pressure plate bolt holes are a lil stripped.. i ran a new tap thru the holes to clean them up... they take tourque spec (19lb/ft i think) but was wondering if i should run a nut on the back side of the flywheel to make sure they dont go anywhere... will this throw the balance off? ... some other suggestions were to retap them to a larger size altogether.... im almost to the point where i would buy a new flywheel for peace of mind. i just dont want to throw the balance off or have the bolts back off. wouldnt mind saving $250 tho.
what do u guys suggest?
A) bolts with nuts on the back side of the flywheel
B) retap holes to a bigger bolt
C) just buy another flywheel
thanks
thanks
