use same aem civic intake after swap??
Old Mar 3, 2004 | 02:28 PM
jdmgeorge's Avatar
Default use same aem civic intake after swap??
Im about to do an ls swap into my eg ...i now have a aem coldair on the stock motor,...will i still be able to use this after the swap? is the opipe diameter to small for the integra manifold? will it hurt performance? thanks!
Old Mar 3, 2004 | 02:56 PM
Lord Helmet's Avatar
Default Re: use same aem civic intake after swap?? (jdmgeorge)
the civic intake will be find if it's the 94-up integras. 90-93 integras would have a problem since the battery is in the way. the diameter is ok as long as you don't go too crazy on the mods.
Old Mar 3, 2004 | 04:44 PM
gloryhog's Avatar
im doing the same swap LS into a EG. what are your plans for this, and oh yeah the aem civic sohc intake will work.where did you buy your ls from?
Old Mar 3, 2004 | 06:47 PM
jdmgeorge's Avatar
Default Re: use same aem civic intake after swap?? (gloryhog)
hey whats up....i got the engine from a local buddy of mine who swapped it out of his integra.....im not sure if i wanna build this yet or turbo it or vtec the head....what about you?
poormans_typer69
Apr 22, 2008 05:11 PM
dynamo
Sep 15, 2006 08:37 AM
jdmgeorge
Mar 3, 2004 03:04 PM
Vp Special K
May 29, 2002 08:07 PM
