Factory Seam Sealer
Old Mar 3, 2004 | 01:31 PM
HamiltonRex's Avatar
Default Factory Seam Sealer
Does anyone know of a equivelent, or a other company that sells something similar.
Its that stuff that is kinda chunky if you have ever picked at it to remove it, and its white inside.
-Eric
Old Mar 3, 2004 | 02:25 PM
Default Re: Factory Seam Sealer (HamiltonRex)
btt
Old Mar 3, 2004 | 03:51 PM
delslow1's Avatar
3M makes seam sealer that's good and LORD FUSOR is also good..
Old Mar 3, 2004 | 04:13 PM
Default Re: (delslow1)
do you have a link to a online place that sells the LORD FUSOR stuff?
What kind of stores do you think would have the 3M Seam sealer.
Thanks,
Would this be the type of thing to use on the inside of a wheel well that has been rebuilt than get the veichle undercoated afterwords?
-Eric
Old Mar 3, 2004 | 04:16 PM
delslow1's Avatar
the LORD FUSOR could be. It is supposed to be about 7 times stronger than a weld. We use it at the body shop when replacing quarter panels and stuff... you can find either one at a body shop supply store....
Old Mar 3, 2004 | 04:46 PM
thanks man.
Ill pick some of it up when i pick up some body filler and primer and paint and stuff at the supplyer.
7 times stronger than a weld, well its already welded, just i need something to seal everything up watertight in the 'non' cosmetic places like under mouldings, fenders etc where i have done some patch welding, since its kinda a tight spot to get a perfectly watertight weld in.\
-Eric
Old Mar 5, 2004 | 05:03 PM
delslow1's Avatar
yep, it should be good for what you need...
Old Mar 5, 2004 | 05:15 PM
swanny's Avatar
Wurth brushable seam sealer
3m adhesiflex(sp?) that comes in a caulk tube
amrussellusn
Paint and Body
Oct 7, 2012 03:13 PM
pleej
Welding / Fabrication
Jun 3, 2009 06:00 AM
hondaboy4life
Jan 10, 2007 07:58 AM
silentblackhat
Dec 30, 2005 08:00 PM
Civic_95_Si
Feb 22, 2003 02:30 PM
