Need someone to verify my TDC on b16 (PICS, to make it easy!!)
Old Mar 3, 2004 | 11:12 AM
rice_classic's Avatar
Post Deleted because I realized my problem has nothing to do with TDC.
Thank you for looking!
Modified by rice_classic at 12:26 PM 3/3/2004
Modified by rice_classic at 2:19 PM 3/3/2004
Old Mar 3, 2004 | 11:31 AM
Katman's Avatar
Default Re: (rice_classic)
this help?
Old Mar 3, 2004 | 01:17 PM
Default Re: (Katman)
What happened was I have more than 1 white mark on my crank pulley but my problem wasn't the TDC setting or the cams being off a tooth... my problem was I had the Adj. cam gears WAY out of spec and it was running rough.
I realized this after I created the post, fixed the problem, car is running great, and I came back to delete the post.
I appreciate your reply anyway, I wish there were more people on H-T like yourself so willing to help!
Old Mar 5, 2004 | 10:02 AM
Katman's Avatar
cool deal..
another way to set the motor to TDC, if the white marks are confusing you is this way:
- Take the spark plug out of cylinder 1
- Use a long skinny stick or post of some sort (more than 12 inches long tho)
- Drop it down into the spark plug hole; the post should be resting on the piston top
- Now, when you hand crank your engine, the post will move up or down since it's riding on the piston
once it reaches its highest point, take a look at your crank pulley. This should help pinpoint which white mark is the correct TDC marking on your crank pulley.
Old Oct 15, 2007 | 04:49 AM
Radyjr's Avatar
awsome pic
WhiteOnRice
Nov 11, 2012 06:54 AM
buddy club vx
18
Jan 1, 2003 04:40 PM
Boo439
Oct 9, 2002 11:24 AM
