how to tighen up the throttle cable?
Old Mar 3, 2004 | 10:09 AM
crazy eyez killa
Guest
Posts: n/a
Default how to tighen up the throttle cable?
How does one tighten a throttle cable? I have a B16
I know youre going to loosen the nut on the cable, near the throttle body, but which way do you adjust the cable to tighten it?
Should it be obvious once i pop the hood and start going at it?
Old Mar 3, 2004 | 10:40 AM
crazy eyez killa
Guest
Posts: n/a
Default Re: how to tighen up the throttle cable? (KURRRWA)
bump
Old Mar 3, 2004 | 11:04 AM
Perfectionist's Avatar
It should become obvious once you start turning the nuts. Beware though... use the correct size and type wrenches to losen and tighten them or you'll round them off.
And... Do not do this to adjust your idle. You'll totally screw things up.
Make sure you leave enough slack in the cable to allow the throttle plate to close fully after the vacuum dashpot pulls in.
Old Mar 3, 2004 | 01:11 PM
crazy eyez killa
Guest
Posts: n/a
Default Re: how to tighen up the throttle cable? (Perfectionist)
thanks
but what do u mean do not do this to adjust your idle?
wouldnt tightening the cable make the car idle a bit better?
bk7794
13
Jun 21, 2012 08:17 PM
v-tec23
Jul 14, 2010 06:24 AM
bseries_beast
Jul 2, 2004 09:25 PM
Simple
Jan 13, 2003 09:44 PM
integra99blue
Jul 16, 2001 07:56 PM
