Hondata #4 with Race Header
Old Mar 3, 2004 | 09:51 AM
tc's Avatar
tc
Default Hondata #4 with Race Header
Hi everyone,
I am looking to get the Hondata 4 and the comptech or toda race header for my rsx-s this spring, but I've been told not to as it will cause the car to run real lean. Is this true?
I want reliable horsepower as this is my only car.
Anyone here have either race header with hondata 4?
Any problems?
Thanks in advance!
Lisa
Old Mar 3, 2004 | 12:49 PM
Z4xLSVTEC's Avatar
Default Re: Hondata #4 with Race Header (tc)
There are several threads on clubrsx regarding this issue. Running the Hondata #4 reflash with a race header does cause the car to run lean in the upper revs. This is so because that flash was not designed with a race-header in mind. You can get around this by purchasing the programmable Hondata ECU and tuning it with your setup. Do a search on clubrsx and you’ll find plenty of info, including information posted by Hondata.
Old Mar 3, 2004 | 11:13 PM
tc's Avatar
tc
Default Re: Hondata #4 with Race Header (Z4xLSVTEC)
Yes, someone else referred me to that site also. I don't want to do the programmable Hondata, because I don't think there's any dealers around here that can tune it.
Old Mar 4, 2004 | 06:33 AM
Z4xLSVTEC's Avatar
If you don't want to deal with tuning, you should just get Hondata #4 and not get a race header. Honestly, whenever you mess around with flow, you will need to adjust for fuel and timing--either with Hondata, VAFC, or some other programmable unit. Look into the Hondata ITR program, I don't know if that has the same issues...but then you'd need to get ITR cams.
Old Mar 4, 2004 | 01:49 PM
Filliam H. Muffman's Avatar
you can buy my type-r header
emaka9
Honda Civic (2006 - 2015)
Jan 27, 2018 11:50 PM
07 rallye red si sedan
65
Jul 25, 2007 07:29 PM
B--RYAN
May 23, 2007 08:11 PM
DIE DIE
Mar 15, 2004 04:21 PM
