Autopower rollbar install - finally done!
Old Mar 3, 2004 | 09:36 AM
Chris N's Avatar
Default Autopower rollbar install - finally done!
It's done! It took a bit too long, but we learned our lesson about tightening things down before everything is connected....
I got home from my friend Wai's house with the bar.... I had removed everything from behind the front seats the previous night while we installed my roommate's Kirk bar in his Hatch.....
We had to move a few wires... no big deal.
Nothing to contend with on the passenger wheel well.... notice the scratches. :eek: When test fitting the bar before drilling holes, we noticed that the rear bars barely fit... thus the scratches. We drew some guides for drilling/placement of the bar, seen in the next few pics.
Well, there were marks for each hole.... Guess I forgot to snap a pic.
Here's one. We punched some small divots in the sheet metal to assist with drilling. You gotta love a 3000rpm, $14 drill. :eek:
We also cut some small holes in the carpet to slide the front plates through.. they didn't turn out great, but not as bad as I first thought.
Test fitting everything before we start bolting everything down.
Me and Bartek were not very happy at this point, we bolted down the rear bars all the way and were unable to fit the main hoop onto them. We ended up loosening things up a bit and everything went smoothly.
Here's my we-todd custom fabrication to make the rear speakers fit.
I dremeled some of the speaker housing off... and we used the two front mounting screws. We drilled the rear mounting screw out, put a zip tie through the hole, and tied the speaker bracket in tight. This makes the speaker's angle more across the car than their previous angle, but they still work, no rattles, no problems. Some slight dremeling of the panel was also necessary.
Everything fits....
Here's bartek working hard... I was in the wheel well.
Just ignore my butt. You'll notice the CRX... which was piled in ITR parts, jackets, food, beer, nuts and bolts, etc. That's about all it is good for with a possibly bad alternator. Also notice my new dent. Someone backed out of my mom's neighbor's driveway while I was over there visiting. Looks pretty nasty, but their insurance is paying.
Bars are in, and bolted down! All that was left is to tighten everything down. Notice the speaker is in there, and the panels fit!
Bart torques while I hold a wratchet down below.
This about sums up what we both think of putting panels back on with the rollbar. Next time... No rear interior at all.
All done!
Note: This is just temporary padding until I get my SFI stuff.
Big huge thanks to Bartek for all his help. Also thanks to BlueR/Marc Tran for the AP Bar. We tackled this project by ourselves for the most part (thanks to Hubert also for his help later on in the evening)... it wouldn't have been so bad had we not tightened down the rear bars and put the panels back on, just to have to take them off, loosen the bars, and play around to get the main hoop attached.
Anyways... That's that.
Modified by Chris N at 1:36 PM 3/3/2004
Old Mar 3, 2004 | 09:38 AM
B2FiNiTY's Avatar
Default Re: Autopower rollbar install - finally done! (Chris N)
Looks GREAT! How many hours did it take?
Old Mar 3, 2004 | 09:39 AM
dk127's Avatar
wow, must have been a pain in the ****..
Old Mar 3, 2004 | 09:40 AM
DsITR's Avatar
looks great homie.. Isn't drilling ho's in the R fun?
Don't forget picking metal ish out of your hands
Old Mar 3, 2004 | 09:41 AM
Chris N's Avatar
Default Re: Autopower rollbar install - finally done! (B2FiNiTY)
Well... if we would have left the panels out, it would have taken only a few hours, 3 at most. But fitting the panels over the top of the rear bars, dremeling, fitting the speakers, and our 'mishap' with tightening the rears down not thinking that we'd have to 'shimmy' the main hoop into the rear bars... that added several hours.
We started at 7pm and finished about 2:30am. We weren't working at breakneck speed, but we weren't loafing around either.
Next time, if there is a next time... I'm not putting panels in.
DsR - Yeh, I had metal shavings in my palms, plastic shavings on my face/stuck on my glasses (from dremeling the panels)... fun.
Drill holes... wow. its amazing how easy it is to get through. Easiest part of the install.
Old Mar 3, 2004 | 09:44 AM
goern-R's Avatar
Looks great! Brings back fond memories of when DMF and I installed my Autopower 6 pt.
Let's just say you did it with far less damage.
Old Mar 3, 2004 | 09:45 AM
shane01itr36's Avatar
Damn that looks good!!!
Old Mar 3, 2004 | 09:46 AM
RockstarJR's Avatar
I was going to put the panels back in mine, but decided I was too lazy
Old Mar 3, 2004 | 09:50 AM
Chris93Si's Avatar
Looks nice, you've inspired me to put my rear speakers back in
Old Mar 3, 2004 | 09:59 AM
H22A EG6's Avatar
Default Re: Autopower rollbar install - finally done! (RockstarJR)
wow trhat is really nice!
Old Mar 3, 2004 | 10:14 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Nice pictures!
I learned from installing the rear sway bar that NEVER tighten the bolts until all the mounting points are in place.
mstewar's Avatar
what made you want to put the rear panels back in?! i mean, it's not like there's a backseat or anything..
Old Mar 3, 2004 | 10:17 AM
Chris N's Avatar
Default Re: Autopower rollbar install - finally done! (mstewar)
I put the panels back in b/c I was going to put the rear seats back in.
Not for use... only to put bags, etc, back there.
I take out my seats to go to the track, but to try to detract from unwanted attention around town.... I want the seats back in.
Old Mar 3, 2004 | 10:18 AM
lanceh's Avatar
25 Year Member
Default Re: Autopower rollbar install - finally done! (Chris93Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si &raquo;</TD></TR><TR><TD CLASS="quote">Looks nice, you've inspired me to put my rear speakers back in </TD></TR></TABLE>
i'd do the same except that would require taking the pannels back out. fock dat sheit!!
Old Mar 3, 2004 | 10:21 AM
Bbasso's Avatar
Looks nice.
Might aswell put the seats in or atleast put the carpeting in so it looks like the showkarr that it is
Old Mar 3, 2004 | 10:23 AM
DarthLuder's Avatar
New User
Chris, stop flipping the bird.
Old Mar 3, 2004 | 10:26 AM
Jon D's Avatar
Looks awesome and very very well done .
Chris N's Avatar
Default Re: Autopower rollbar install - finally done! (ITR GURU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR GURU &raquo;</TD></TR><TR><TD CLASS="quote">Chris, stop flipping the bird.</TD></TR></TABLE>
Damn, where's my cigarette?
We smoke while we shoot the bird....
Old Mar 3, 2004 | 10:27 AM
BlueR's Avatar
Default Re: Autopower rollbar install - finally done! (Bbasso)
no love for the BlueR?
everything looks great chris
Old Mar 3, 2004 | 10:28 AM
Ausmith's Avatar
Looks good dude!
Old Mar 3, 2004 | 10:35 AM
Chris N's Avatar
Default Re: Autopower rollbar install - finally done! (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">no love for the BlueR?
everything looks great chris </TD></TR></TABLE>
Damn!! I knew I forgot someone.
Another Big thanks to Marc Tran!!!
Old Mar 3, 2004 | 10:41 AM
.RJ's Avatar
.RJ
Ban.
Old Mar 3, 2004 | 10:42 AM
BlueR's Avatar
Default Re: Autopower rollbar install - finally done! (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Ban.</TD></TR></TABLE>
Old Mar 3, 2004 | 10:48 AM
Chris N's Avatar
Old Mar 3, 2004 | 10:51 AM
Mugen Mike's Avatar
Looks g00t, Chris. Looking forward to seeing your hack job in person
