Need some input from u CF hood owners
Old Oct 15, 2001 | 08:26 PM
Toda Party's Avatar
Default Need some input from u CF hood owners
Well, i got my CF hood in today, and after some finnageling, i got it on, but the fitment isn't too great as u can see....any advice ? i'm going to try raising the rubber supports, and playing around with the flaps that hold the hood onto the car...any other advice/suggestions?
Old Oct 15, 2001 | 08:30 PM
PrjctDC2-R's Avatar
New User
Default Re: Need some input from u CF hood owners (Toda Party)
what are you talkin about ??! it fits perfect .. what kind of CF hood is that btw?
[Modified by PrjctDC2-R, 9:30 PM 10/15/2001]
Old Oct 15, 2001 | 08:32 PM
AllMotorBLKITR731's Avatar
New User
Default Re: Need some input from u CF hood owners (PrjctDC2-R)
no it doesn't. you can practically see parts under the hood...
[Modified by AllMotorBLKITR731, 5:33 AM 10/16/2001]
Old Oct 15, 2001 | 08:47 PM
Toda Party's Avatar
lol...its fiberimages....i bought this off carlex and on his pix it looked perfect, so im going to screw around with it...i hope i never have to put my stock hood back on...that would suck
Old Oct 15, 2001 | 08:51 PM
Keyed ITR's Avatar
Default Re: Need some input from u CF hood owners (MiGs)
You should get a clearcoat on that. Hope that's not a Fiberimages, they usually have poor inspection grades.
Old Oct 15, 2001 | 09:00 PM
Toda Party's Avatar
Default Re: Need some input from u CF hood owners (Keyed ITR)
yeah carlex applied a clear coat already....sorta good since airbone express totally killed the hood in delivery and theres scuff marks and scratches all over the place - for 73 bucks i expected more
Old Oct 15, 2001 | 09:17 PM
Flamenco-T's Avatar
take off the black rubber weather strip on the edge of your stock hood and attachs it to the CF hood to close the gap on the front sides..I use a jb weld
on your bay, there are two rubber stopper that can be turn clockwise to lower it or counter to raise it....I turned mine clockwise to lower it.
on the hinges area, I trim the original hole on the hinges using dremel and enlarged the holes towards the front, by pushing the hood mounting location a little towards the front, it'll lower the position of the hood around the hinges area.....
one more advice, DO NOT ALTER the mounting area of the hood. I tried to trim off the mounting area of the hood hoping it'll lower the area around the hinges, I stripped the nuts that hold the hood to the bolts, and ended up having to order a new nuts and applied 4 layers of fiberglass to get it fixed..making it even worse...
just play around the hinges to get it lower..
I have fiberimages too, I have seen about 5 FI hood on a teg, and none of them seems to have a perfect fit....I called FI and explain my problem, and their only response was, as quoted " we could never get the integra's hood to fit right "
but they did took care of me when I need a new sets of nuts to fix my hood..so that was really cool of them...
hope this helps, I'll be more than happy to help more if I can..
Old Oct 15, 2001 | 09:37 PM
Toda Party's Avatar
Default Re: Need some input from u CF hood owners (flamenco)
hey thanks a lot...we were trying to do it but it was getting cold, it was dark, and we said screw it...it stayed on at 105 mph fine so im not too worried about it flying, just about it looking nasty...this weekend is going to be some test and tune lol..thanks again
its just that sides above the fenders on each side dont sit right...everythingelse is fine..it wouldnt latch at first but we raised the locking mechanism a little higher..but i dont know why it sits above the fenders so high
[Modified by Toda Party, 6:40 AM 10/16/2001]
Old Oct 15, 2001 | 09:54 PM
B2FiNiTY's Avatar
Got any pics of your car with the hood flamenco?
Old Oct 15, 2001 | 10:40 PM
oOxsboostOo's Avatar
New User
as a last resort.... you can loosen or remove the body bolts along the top of the fender and actually push the fender in just a little bit. Every single car has small imperfections, this is an easy way to combat that.
Also, if the fender itself sits lower than the hood in some areas try adding a shim to raise the hood 1/16th or 1/8th of an inch or so on. Depending on the gap, this should be easy to remedy.... just watch the gap on your front bumper. Body shops have to do this constantly to hide their shi##y frame repair.
[Modified by oOxsboostOo, 7:41 AM 10/16/2001]
Old Oct 15, 2001 | 11:50 PM
immortal's Avatar
Banned
Default Re: Need some input from u CF hood owners (oOxsboostOo)
my hood seemed to fit well. its a fiber images
did i get lucky?
when i first installed it it looked like ****. i had to play around with it a lot and then i finally got it right.
Old Oct 16, 2001 | 08:12 AM
Toda Party's Avatar
Default Re: Need some input from u CF hood owners (immortal)
that looks gooooood. hopefully whe we try to adjust it again, it wont be in the dark freezing cold so we'll do a better job lol
Old Oct 16, 2001 | 05:13 PM
Flamenco-T's Avatar
Default Re: Need some input from u CF hood owners (B2FiNiTY)
the resolutions is not too great..but here it is..
Old Oct 16, 2001 | 05:28 PM
ITR #1202's Avatar
Hey I really like your R where can I get fog/runnnig lights like
that?
Old Oct 16, 2001 | 05:29 PM
Flux's Avatar
Default Re: Need some input from u CF hood owners (ITR #1202)
that?
Those look like the factory OEM fog lights if I am not mistaken....
Old Oct 16, 2001 | 05:34 PM
ITR #1202's Avatar
Default Re: Need some input from u CF hood owners (Flux)
where can I get OEM fog lights?
Old Oct 16, 2001 | 05:38 PM
Jason's Avatar
where you get all OEM parts, from the Acura dealer (or try Mike K on this board, he can save you some cash i"m sure)
Flux's Avatar
OEM means "Original Equipment Manufacturer" - or in other words they are made (probably not literally) by Honda/Acura. Talk to your parts guy at your local dealership...
Old Oct 16, 2001 | 05:40 PM
ITR #1202's Avatar
cool thanks for the help
Old Oct 16, 2001 | 06:09 PM
Toda Party's Avatar
MMMMM black with bronze te-37s. stop copying me. well..., my dream setup anyway
Old Oct 16, 2001 | 07:55 PM
BodyKits NW's Avatar
Your just going to have to play around with the hood a little. Someome posted a pretty good explination a few post up. The fitment of those hoods are just very inconsistant. A lot of local customers and people they deal with directly at there shop get the better stuff. Such as racing teams or big orginizations.
Old Oct 16, 2001 | 08:03 PM
PROFILE EK4's Avatar
New User
Default Re: Need some input from u CF hood owners (BodyKits NW)
move the hoodlatch down...all you have to do is elongate the holes in yer latch...then its a matter of fine tuning it..
Old Oct 16, 2001 | 09:36 PM
ringgold's Avatar
Default Re: Need some input from u CF hood owners (PROFILE EK4)
I got a fiber images hood and it didnt fit well at all. It isnt for an ITR but it still took me and a friend about half the night to make it fit as good as it does now. And like in the first pic you can see down into the engine bay on mine also. Oh well I still like it.
Old Oct 16, 2001 | 09:47 PM
Flamenco-T's Avatar
Default Re: Need some input from u CF hood owners (ringgold)
ITR#1202: check your IM
it is the factory fog light kit...and it is actually a GSR, not an ITR..
boosted GS-R though..hahahah
Old Oct 16, 2001 | 10:09 PM
DR. ON POINT's Avatar
Banned
dont get a hood from importfan.com they turn green after like 3 months...also the people ther tried to charge twice for the hood...they're *** holes
